Catalyst 2960x
I have update Catalist 2960x switch with latest firmware and its web interface is not working. Screenshots attached. What could be the problem.
15 Replies 15
Hello @srinivasthotakuri ,
there are no screenshots attached. Please attach them in order to see what the problem could be and fix it.
Regards, LG
*** Please Rate All Helpful Responses ***
Please find the screenshot
Leo Laohoo
Because someone "upgraded" the IOS by manually copying the BIN file to the switch and the HTML files are not compatible or not included.
##- The following was uploaded
c2960x-universalk9-tar.152-7.E9 -##
With regards
टी श्रीनिवास/ T.Srinivas
प्रबंधक (आईटी)/ Manager(IT / C&I)
रामगुंडम/NTPC-Kayamkulam
Mobile : 945002522
Land line: 04792365021
[G20]
Volgash
Hi @srinivasthotakuri
Would you please tell me how that updated the 2960x switch works?  The @Leo Laohoo 's answer is one of the most possible scenarios. To facilitate a comprehensive assessment, I kindly request the following information:
sh ver
dir
sh boot
Thank you.
##- Sw@FacilityFF#sh ver dir boot
% Invalid input detected at '^' marker.-##
With regards
Mobile : 945002522
[G20]
Post the complete output to the following command:
dir
##- Sw@FacilityFF#dir
Directory of flash:/
497 -rwx 3585 Mar 14 2024 09:40:05 +05:30 config.text
2 -rwx 3403 Mar 14 2024 09:40:05 +05:30 private-config.text
3 -rwx 2003 Dec 8 2015 17:40:01 +05:30 config.old
4 -rwx 976 Jun 1 2016 17:16:48 +05:30 vlan.dat
5 -rwx 3096 Mar 14 2024 09:40:06 +05:30 multiple-fs
649 drwx 512 Mar 13 2024 09:59:07 +05:30 c2960x-universalk9-mz.152-7.E9
498 drwx 512 Mar 13 2024 09:59:08 +05:30 dc_profile_dir
122185728 bytes total (80289280 bytes free)
Sw@FacilityFF#-##
With regards
Mobile : 945002522
[G20]
How about this:
dir flash:c2960x-universalk9-mz.152-7.E9
##- Sw@FacilityFF#dir flash:c2960x-universalk9-mz.152-7.E9
Directory of flash:/c2960x-universalk9-mz.152-7.E9/
6 -rwx 688 Mar 13 2024 09:43:16 +05:30 info
8 -rwx 26789888 Mar 13 2024 09:43:24 +05:30 c2960x-universalk9-mz.152-7.E9.bin
9 drwx 1536 Mar 13 2024 09:53:11 +05:30 html -##
With regards
Mobile : 945002522
[G20]
you need tar file to get all the GUI features. follow below thread :
https://community.cisco.com/t5/switching/cisco-2960-x/td-p/4577950
BB
Please explain the meaning of "its web interface is not working"?
balaji.bandi
Question is is that worked before - or never worked ?
in this folder if you have - html folder  -
#dir flash:c2960x-universalk9-mz.152-7.E9/html/
Then probably you have configuration issue.
can you post show run  | in http   - do you see http config - if not follow below instructions.
config t
username balaji privilege 15 password balaji123
ip domain-name bb.com
crypto key generate rsa general-keys mod 2048
ip http server
ip http secure-server
ip http authentication local
end
from PC then try https://switchip  (thinking that you already configured IP address on switch)
BB
Still it is not working
