Catalyst 3560 inter vlan routing
benpridmore
Hi there.
Can anyone help me to configure a layer 3 switch to route between vlan's. I cant seem to get it to work. There's already configuration on the router which i didnt configure (im not sure if this is reason its not working).
I need to route from 10.0.0.x/24 to 10.0.2.x/24.
10.0.0.x is already configured as vlan 1 on the GigabitEthernet port.
Vlan 2 is already routing across a fiber link on port 1.
Iv setup vlan for the 10.0.2.x network with port 8, i just cant get them to route.
Can anyone help me do this? - running-config below.
Ben
show running-config
Building configuration...
Current configuration : 1726 bytes
version 12.2
no service pad
service password-encryption
hostname Switch-One
boot-start-marker
boot-end-marker
enable password
username lac password
username bpridmore password
aaa new-model
aaa session-id common
system mtu routing 1500
ip routing
ip domain-name rrca.net.au
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0/1
switchport access vlan 2
speed 100
duplex full
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
switchport access vlan 3
switchport mode access
interface GigabitEthernet0/1
interface Vlan1
ip address 10.0.0.251 255.255.255.0
interface Vlan2
description Fibre Link
ip address 10.254.253.1 255.255.255.252
interface Vlan3
ip address 10.0.2.249 255.255.255.0
interface Vlan4
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.138
ip route 192.168.50.0 255.255.255.0 10.254.253.2 permanent
ip route 192.168.60.0 255.255.255.0 10.254.253.2 permanent
ip http server
no ip http secure-server
access-list 2000 permit icmp any any
access-list 2001 deny   ip host 192.168.60.254 10.254.253.0 0.0.0.255
access-list 2002 deny   ip host 192.168.60.254 10.0.0.0 0.0.0.255
access-list 2003 permit ip 192.168.60.0 0.0.0.255 any
line con 0
line vty 0 4
transport input telnet
line vty 5 15
transport input ssh
end
10 Replies 10
Richard Burts
Ben
I am not clear about some parts of the description of your problem. Does port 1 in vlan 2 have any real part in the problem that you describe. It is not evident to me that it does. So please provide some clarification.
There is one port (port 8)  in vlan 3. Can you tell us what is connected to this port? And can you tell us the status of this port and the status of interface vlan 3?
The output of show ip interface brief and the output of show interface status would be helpful.
The configuration of routing seems appropriate and I do not see particular issues in the routing configuration. So I am wondering about the possibility that it is an interface status issue that is preventing routing.
Rick
Rick
Thanks for your reply Rick.
No, i dont think port one will have a part in this problem, i just thought id explain the entire situation.
Port 8 is connecting to the network 10.0.2.x.
show ip interface brief:
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.0.0.251      YES NVRAM  up                    up
Vlan2                  10.254.253.1    YES NVRAM  up                    up
Vlan3                  10.0.2.249      YES NVRAM  down                  down
Vlan4                  unassigned      YES NVRAM  down                  down
FastEthernet0/1        unassigned      YES unset  up                    up
FastEthernet0/2        unassigned      YES unset  down                  down
FastEthernet0/3        unassigned      YES unset  down                  down
FastEthernet0/4        unassigned      YES unset  down                  down
FastEthernet0/5        unassigned      YES unset  down                  down
FastEthernet0/6        unassigned      YES unset  down                  down
FastEthernet0/7        unassigned      YES unset  down                  down
FastEthernet0/8        unassigned      YES unset  down                  down
GigabitEthernet0/1     unassigned      YES unset  up                    up
show interface status:
Port      Name               Status       Vlan       Duplex  Speed Type
Fa0/1                        connected    2            full    100 10/100BaseTX
Fa0/2                        notconnect   1            auto   auto 10/100BaseTX
Fa0/3                        notconnect   1            auto   auto 10/100BaseTX
Fa0/4                        notconnect   1            auto   auto 10/100BaseTX
Fa0/5                        notconnect   1            auto   auto 10/100BaseTX
Fa0/6                        notconnect   1            auto   auto 10/100BaseTX
Fa0/7                        notconnect   1            auto   auto 10/100BaseTX
Fa0/8                        notconnect   3            auto   auto 10/100BaseTX
Gi0/1                        connected    1          a-full a-1000 10/100/1000BaseTX
Thanks again mate.
Ben
Hello Ben,
Please check the following steps to see if the intervlan routing is working:
  1. Make sure that the PC's default gateway is set to the corresponding VLAN interface IP address
  2. Ping from the PC to all the IP addresses on the Switch. If this step is successful, then InterVLAN routing is working.
  3. Now ping the remote destination. If it is not working, check the remote destination/router to see if there is a route to your local network.
This should help you identify the cause for routing failure.
Hope this helps.
Nagaraja
Nagaraja
It is most important for Ben to solve the issue of why port 8 shows that it is down and not connected. After he figures this out and fixes it your suggestions may be appropriate.
Rick
Rick
benpridmore
Thanks for your replies.
I had disconnected port 8 for a moment because i deleted vlan 3 and didnt want a dhcp issue. Once i recreated vlan 3 i connected it again.
Let me explain the setup in more detail.
Both networks use a unmanaged switch. Since vlans cant be added to these switches would this be a problem?
Both networks also use srp527w routers. I have added a static route to the "other network" using the ip address of each vlan as the gateway (i know this may not be correct).
I know routing the networks should be possible using a layer 3 switch.
Knowing more can either of you suggest a better way of solving this problem?
Thankyou both for your help.
Ben
Hi Ben
So you have access switches which are supposed to be using Vlans 3 and 4 but these switches are not capable of Vlan tagging?
  If you just have dumb switches of of those ports you should be able to route with no issues. No static routes are needed .  Devices on those vlans need their default gateways pointed at the 3560 SVI for the appropriate vlan .
Post a show vlan , show ip route  from the 3560.  Of course those ports must be in a connect status for them to work.
Besides that don't see an issue , they should be in "switchport access vlan X"  which they are.  Also if you are trying to ping windows devices you must turn off windows firewall to be able to ping those devices.
Ben
Thanks for the explanation about the situation with port 8. If that is now up/up then this addresses one of the issues. In that output that you posted I also note that there were multiple ports on the switch that are in vlan 1 but that only interface Gig0/1  shows as connected and up. Is this the port where the other switch is connected?
If an unmanaged switch is connected to interface Fast0/8 then all of its ports should be in vlan 3. And if another unmanaged switch is connected to interface Gig0/1 then all of its ports should be in vlan 1. And the switch configuration that you posted looks to be appropriate for routing between these vlans. So a bit more output might be helpful. Can you post the output of the command to show the entries in the switch mac address table? Also the output of show arp from the switch.
One of your posts mentions having srp527w routers in the network. I am not clear whether they are playing a role or not. If the PCs are connected and receiving addresses via DHCP then it would be helpful to check and see what is configured for their default gateway. If the PC default gateway is the address of the switch interface then routing should work. And if their default gateway is the srp527w then this may explain why routing is not working.
Rick
Rick
benpridmore
Correct, the layer2 switches are not capable of vlan tagging. Iv added a static route from the 10.0.0.138 router to 10.0.2.x using the ip address vlan on the layer 3 switch (10.0.2.249).
A ping request shows this is working:
Ping has started…
PING 10.0.2.6 (10.0.2.6): 56 data bytes
Request timeout for icmp_seq 0
92 bytes from 10.0.0.138: Redirect Host(New addr: 10.0.0.251)
Vr HL TOS  Len   ID Flg  off TTL Pro  cks      Src      Dst
4  5  00 0054 7f2d   0 0000  3f  01 e651 10.0.0.37  10.0.2.6
A ring request to vlan 3's address works
The switch is using the Gig0/1 port to connect to vlan 1. DHCP is coming from a server on the 10.0.0.x and the router on the 10.0.2.x. The default gateways on both networks are set to the router (10.0.0.138 & 10.0.2.138)
show arp-
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.2.9               91   5426.96ce.8863  ARPA   Vlan3
Internet  10.0.0.8               10   28cf.e908.6345  ARPA   Vlan1
Internet  10.0.2.14             144   3415.9e90.1b19  ARPA   Vlan3
Internet  10.0.2.15              73   3c07.545f.f5a4  ARPA   Vlan3
Internet  10.0.0.2                0   70cd.60aa.99eb  ARPA   Vlan1
Internet  10.254.253.1            -   f41f.c2f1.26c1  ARPA   Vlan2
Internet  10.0.0.3                0   0025.9011.6baf  ARPA   Vlan1
Internet  10.254.253.2          107   f41f.c262.0cc1  ARPA   Vlan2
Internet  10.0.2.5               57   f81e.dfdd.7c4b  ARPA   Vlan3
Internet  10.0.2.6                7   3c07.545f.f5a4  ARPA   Vlan3
Internet  10.0.2.24               0   040c.ce1d.3fbe  ARPA   Vlan3
Internet  10.0.0.27              75   0023.df94.8dea  ARPA   Vlan1
Internet  10.0.2.16              69   0023.6c99.d717  ARPA   Vlan3
Internet  10.0.2.21               4   78a3.e44f.783b  ARPA   Vlan3
Internet  10.0.0.23               0   0023.1213.9314  ARPA   Vlan1
Internet  10.0.2.23              24   0000.747a.75cc  ARPA   Vlan3
Internet  10.0.0.38              85   406c.8f38.bff5  ARPA   Vlan1
Internet  10.0.2.37               0   Incomplete      ARPA
Internet  10.0.0.36              86   3415.9e90.1b19  ARPA   Vlan1
Internet  10.0.0.37               0   58b0.35f3.2560  ARPA   Vlan1
Internet  10.0.0.138              0   203a.0754.7c21  ARPA   Vlan1
Internet  10.0.2.138              4   203a.0754.7b35  ARPA   Vlan3
Internet  10.0.0.200              0   70cd.60aa.9900  ARPA   Vlan1
Internet  10.0.2.249              -   f41f.c2f1.26c2  ARPA   Vlan3
Internet  10.0.0.251              -   f41f.c2f1.26c0  ARPA   Vlan1
Thanks for your help guys. I feel this is close to working now.
Ben
Ben
I am glad that we have made progress. The output of show arp would seem to me to indicate that things are working. At least what I am seeing, in particular, is that the switch has MAC addresses in the arp table for devices in vlan 1 and also for devices in vlan 3. So from what I can see it should be routing between those vlans/subnets.
If there are devices that are not working (can not access devices on the other vlan) then my first suggestion would be to check and see if their default gateway is pointing to this switch.
I also notice that you have referred again to a router in the network. I am still not clear about the router and what its function is, and therefore not clear whether the router is part of what is causing whatever problem you may still be having.
Perhaps you can provide some clarification about what is not yet working?
Rick
Rick
