Catalyst 3560 solid green LED's after boot
elwe31
Community Member
Hi all,
I start my cisco Catalyst 3560G PoE-48 since a long time off.
All LED stay green(see the attachment) and the fan blows hard always !
No data received in consol.
I tried start with the button "Mode" push, it's the same.
Thanks for your help.
Best regards
7 Replies 7
balaji.bandi
Connect console cable to device, Turn off (wait for 5min) and Trun on the device - do you see any console output post here.
if not the device has issue with POST issue.
BB
Thanks for your reply,
Nothing in the consol after turn off/on.
  - Looks bad try factory reset , see if that can 'kick' output on the console.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
have seen this issue, the kit is dead as per i know...(if you do not have anything on the console)
BB
The kit ?
 - Probably referring to the kid (kid-ding). Poster denotes possible fatal hardware problem.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
kit ( aka - the device or switch)
BB
