Catalyst 3560 vlan trunks over etherchannel
bsternfield
I'm configuring two etherchannel groups (2 ports in each) on a 3560 switch.  I need to trunk multiple vlans over each channel group.
I created the vlan trunks and allowed vlans on each physical interface.  I notice that I can also configure the vlan trunks on the port-channel interfaces that were created. Should I configure them under those interfaces, or leave them on the physical interfaces?  Relevant config is below:
interface Port-channel1
interface Port-channel2
interface FastEthernet0
no ip address
interface GigabitEthernet0/1
switchport trunk allowed vlan 2,7,9
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet0/2
interface GigabitEthernet0/3
channel-group 2 mode active
interface GigabitEthernet0/4
Thanks.
smehrnia
Level 7
Level 7
configure whatever attribute you need for the links under the Po1 and Po2 interfaces, whats important here is that all your physical links in a boundle have the same characteristic (L2, L3, etc). The rest is to be done under port channel int when created.
"After you configure an EtherChannel, configuration changes applied to the port-channel interface apply to all the physical ports assigned to the port-channel interface. Configuration changes applied to the physical port affect only the port where you apply the configuration. To change the parameters of all ports in an EtherChannel, apply configuration commands to the port-channel interface."
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
smehrnia
Level 7
Level 7
Soroush.
Hope it Helps!
Soroush.
