HSRP interface tracking on IOS XR
For many years I have configured HSRP on my IOS based devices with tracking configured for a Loopback without an IP so that during maintenance windows one simply needs to down the loopback to fail HSRP to the peer. However, recently when configuring the same setup on an ASR9K, I noticed that while the loopback shows up/up, HSRP sees it as down (config/output below). The only way to get HSRP to see the loopback as up is by configuring an IP on the loopback.
Does anyone know if this is intentional/expected behavior? Again, in IOS and NX-OS you do not need an IP on the loopback for HSRP to see it as up and track accordingly.
Thanks!
RP/0/RSP0/CPU0:ASR9K#sh int lo192
Tue Jun 12 22:18:47.134 MST
Loopback192 is up, line protocol is up
  Interface state transitions: 1
  Hardware is Loopback interface(s)
  Description: HSRP Tracking - DO NOT DOWN
  Internet address is Unknown
  MTU 1500 bytes, BW Unknown
     reliability Unknown, txload Unknown, rxload Unknown
  Encapsulation Loopback,  loopback not set,
  Last input Unknown, output Unknown
  Last clearing of "show interface" counters Unknown
  Datarate information unavailable.
  Interface counters unavailable.
RP/0/RSP0/CPU0:ASR9K#sh run router hsrp
router hsrp
interface TenGigE0/0/0/2
  hsrp 1 track Loopback192 200
  hsrp 1 preempt
  hsrp 1 ipv4 X.X.X.X
  hsrp 1 priority 255
RP/0/RSP0/CPU0:ASR9K#sh hsrp te0/0/0/2 det
Tue Jun 12 22:18:53.054 MST
TenGigE0/0/0/2 - Group 1
  Local state is Standby, priority 55, may preempt
  Hellotime 3 sec holdtime 10 sec
  Minimum delay 1 sec, reload delay 5 sec
  Hot standby IP address is X.X.X.X configured
  Active router is X.X.X.Y, priority 100 expires in 00:00:07
  Standby router is local
  Standby virtual mac address is 0000.0c07.ac01
  6 state changes, last state change 00:12:18
  State change history:
  Jun 12 22:05:59.547 MST  Init     -> Listen   Delay timer expired
  Jun 12 22:06:09.549 MST  Listen   -> Speak    Active timer expired
  Jun 12 22:06:19.551 MST  Speak    -> Standby  Standby timer expired
  Jun 12 22:06:19.551 MST  Standby  -> Active   Active timer expired
  Jun 12 22:06:24.195 MST  Active   -> Speak    Higher priority active received
  Jun 12 22:06:34.197 MST  Speak    -> Standby  Standby timer expired
  Last coup sent:       Never
  Last coup received:   Jun 12 22:06:24.209 MST
  Last resign sent:     Jun 12 22:06:24.195 MST
  Last resign received: Never
  Tracking interface states for 1 interface, 0 up:
    Down Loopback192 Priority decrement: 200
smehrnia
Level 7
Level 7
Hi Tim,
Yes, its an expected behaviour of ios xr that only IP interfaces are tracked. A tracked interface is up if IP on that interface is up. Otherwise, the tracked interface is down.
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
