Catalyst 3560
isaacmora
Community Member
I have a cisco catalyst 3560 and i want to know how to block communication between two diferent vlan
Let's suppose  you want vlan 2 and vlan 10 not to communicate between them, just do something like this:
int vlan 2
ip address 192.168.2.1 255.255.255.0
ip access-group 199 in
int vlan 10
ip address 192.168.10.1 255.255.255.0
access-list 199 deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 199 permit ip any any
Regards.
Alain
5 Replies 5
Tom Watts
Hi Isaac, in a layer 2 environment, intervlan communication does not happen. All requests go to the router then the router permits the intervlan communication. You may apply an access list on the interface connecting to the router.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
If you use the 3560 as Layer 3 switch with interface VLAN, you can use ACL to stop intervlan communication or the command "no ip routing" to disable L3 features.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Regards.
isaacmora
Community Member
hi thomas
the catalyst 3560 is a L3 switch, i want to know how i canuse ACL to stop intervlan communication
int vlan 2
int vlan 10
Regards.
Alain
Good morning isaac mora
With the command  “ip access-group (ACL-Name) in” you can block access to other vlan,
For example, let's say you have 4 VLAN's  and a WAN conection.
Vlan10  192.168.10.0/24
Vlan20  192.168.20.0/24
Vlan30  30.0.0.0/8
Vlan40  192.168.0.0/16
Wan     10.10.10.0/30
This is the configuration:
ena
config t
ip routing        -->Enable routing features
vlan 10        -->Creates your Vlan10
name Block
exit
ip access-list extended DenyVLAN-10                                                      -->creates an ACL to deny the networks (VLAN's)
deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255                              -->denies vlan 20
deny ip 192.168.10.0 0.0.0.255 30.0.0.0 0.255.255.255                              -->denies vlan 30
deny ip 192.168.10.0 0.0.0.255 192.168.40.0 0.0.255.255                    -->denies vlan 40
permit ip any any        -->allows access to the internet
exit
interface Vlan10
ip address 192.168.10.254 255.255.255.0
ip access-group DenyVLAN-10 in                                                              -->associate the ACL to VLAN10
interface Vlan20
ip address 192.168.20.254 255.255.255.0
exit
interface Vlan30
ip address 30.0.0.0 255.0.0.0
exit
interface Vlan40
ip address 192.168.40.254 255.255.0.0
exit
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Greetings,
Johnnatan Rodriguez Miranda
