Catalyst 3650 and SG200 Etherchannel
amantsios
recently we bought 2 SG200 to expand our network to Gigabit.We own 1 Catalyst 3650.
We tryed to Etherchannel between the Catalyst and one SG200 but with no luck.
At Catalyst i created the port channel
interface Port-channel1
switchport mode access
and put 4 ports on it
interface GigabitEthernet0/45
channel-group 1 mode on
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
when i do show interface port-channel 1 i get that
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 001a.a24d.00ae (bia 001a.a24d.00ae)
  MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi0/45 Gi0/46 Gi0/47 Gi0/48
  Last input 00:00:16, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 988000 bits/sec, 166 packets/sec
  5 minute output rate 1943000 bits/sec, 224 packets/sec
     3283827412 packets input, 3257328668 bytes, 0 no buffer
     Received 34678609 broadcasts (0 multicast)
     10 input errors, 10 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 8423441 multicast, 0 pause input
     1976995515 packets output, 241528325 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
I can see that the port-channel is 4Gbit but into the SG200 web interface the Link stays at 1Gbit
I also giving you 2 screenshots from the sg200.
Am i doing something wrong?
Do you have any suggestions?
Is able sg200 to create etherchannel with the Catalyst?
Thanks in Advanced
Alex
andtoth
Level 4
Level 4
Hi Alexander,
Please note that Etherchannel "mode on" will only work between Cisco devices. Therefore, could you try using LACP by configuring "mode active" on the Cisco switch, and enabling LACP (also known as LAG or 802.3ad) on the SG200 device?
Please refer to the following documentations as well.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094647.shtml
Best regards,
Andras
   Mode on should work on servers or cisco switches.   PAGP will only work between cisco switches because it is cisco proprietary.
Florin Barhala
Level 6
Level 6
Did you run a BW test? Maybe it's just a BUG in the webview. As long as the Catalyst see the link to 4Gbps I see no problem.
