Catalyst 3750 in Provisioned mode
gagamboy15
Hi Guys,
Recently our network has slows down, ping response to local server is high about 500~800ms, and when I logged-in to our 8x 3750 stack and issue the command below, I found this:
#Show switch
Switch#  Role      Mac Address     Priority     State
*1       Master    0013.8020.e780     15        Ready
2       Member    0000.0000.0000     0        Provisioned
3       Member    0013.8015.8980     13        Ready
4       Member    0013.801c.df00     12        Ready
5       Member    0013.8020.d380     11        Ready
6       Member    0000.0000.0000     0        Provisioned
7       Member    0000.0000.0000    0         Provisioned
8       Member    0018.73fc.9c00     1         Ready
     1  11111111 1 1  1 1111111 11   11111111111984
     0991110000090929909001011190199900110012200906
100                                             *
90                                             *
80                                             **
70                                             **
60                                             **
50                                             ***
40                                             ##*
30                                             ##*
20                                             ##*
10  #############################################*
    0....5....1....1....2....2....3....3....4....4....5....5....
              0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
Recently, all Switch are working working and in ready state, what could be the problem on this? Also the LED on every port is blinking fast. I have also installed spanning-tree bpduguard in every port to prevent loop.
Thanks in advance.
regards,
gagamboy
martin_knorre
have you treid to remove the Switch from the stack, if no try to issue no switch * provision and after that switch * provision + reload of the stack member.
Let me know if you have more trouble with it ;-)
Rgds Martin
Latchum Naidu
We have experienced this same issue before 3 months.
Cisco 3750's in a stack...plenty of good power....been running for a long time.
We have 6 in our stack, and #1 and #4 both put themselves in provisioned mode at the same time.
I don't think the switches were really in provision mode...commands to take them in and out of that mode did not do anything.
You could just resetting just the "provisioned" switch by just reloaded the whole thing and dealt with the aftermath of doing so.
And the below link is pretty good at explaing the whole stack cenario.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
Hope this will help you.
Please rate the helpfull posts.
Naidu.
Thanks for the feedback guys.
Actually I have rebooted the switches 2 times now, last week and now. The switch are working just fine a couple years ago and I am wondering how did this happen. CPU is high and blinking LED is quite faster than normal, so I am suspecting there could be some problem with the network right now. We don't want to reload the switches every time this problem occurs :-)
thanks again.
regards,
Gagamboy
