Catalyst 4006 supporting 10GBit??
stratmann83
Hello guys,
is there any kind of solution running a WS-C4006 with a 10 GBit Module? And if yes, which
are compatible? I can´t find anything about it on the homepage. Seems it does only
support Gigabit.
Thanks for help
glen.grant
   If you are talking a catos box then the answer is no , only  supports gigabit cards .  If you are talking  a IOS supervisor in a 4006 chassis then  it might.  Just read the release notes  for whatever  version it is . It tells you what hardware and cards are supported.
Leo Laohoo
Depends on what Supervisor Card you are using.
Besides, the 4000-series chassis can't really push anything near 5Gb per chassis or per slot.
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_data_sheet09186a00800924ec.html
