ā07-17-2018 06:51 AM - edited ā03-08-2019 03:42 PM
Hello Dears
I have a problem , my core router 6500 when i reload it or power cycle it , it doesn't load the configuration i saved it loads the ios image that contains no config at all , how can i make it load the image that contain all of the config i saved , another issue i have is that when i try the
router(config)boot supboot-disk0:ios image
it says that there is no HA to support the boot config
i need to load the ios image that i want and save all configuration in it and when i reload it , it should load the latest configuration that i saved
thanks
ā07-17-2018 07:10 AM
Hello!
Which is the "show bootvar" output? please paste the "show ver" and show bootvar from the device here.
Best Regards,
ā07-17-2018 07:17 AM
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASE-M), Version 12.2(33)SXH3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 24-Sep-08 07:00 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
Router uptime is 3 minutes
Uptime for this control processor is 3 minutes
Time since Router switched to active is 2 minutes
System returned to ROM by power cycle at 21:29:36 UTC Mon Jul 16 2018 (SP by power on)
System image file is "sup-bootdisk:s72033-ipbase-mz.122-33.SXH3a.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory.
Processor board ID SAL09051FEN
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
126 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
ā07-17-2018 07:20 AM
Router#show bootvar
BOOT variable =
CONFIG_FILE variable =
BOOTLDR variable =
Standby is up
Standby has 1048576K/65536K bytes of memory.
Standby BOOT variable =
Standby CONFIG_FILE variable = sup-bootdisk:sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
ā07-17-2018 07:25 AM
Did you try to set the boot image you want to use this way?
boot system disk0:s72033-adventerprise-mz.151-2.SY7.bin
Please do not forget to rate useful post.
Best Regards,
ā07-17-2018 07:32 AM
i tried this but it doesn't show disk0
Router(config)#boot system ?
WORD TFTP filename or URL
flash Boot from flash memory
ftp Boot from a server via ftp
mop Boot from a Decnet MOP server
rcp Boot from a server via rcp
tftp Boot from a tftp server
and tried this but the output says HA support is not available
Router(config)#boot config sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin
%WARNING: HA support is not available to " boot config " command
any ideas ?
thanks
ā07-17-2018 07:24 AM
Hello Diana
thanks for your reply , i want to load this image
and save configurations in it and if i reload the router or power cycle it
it should load the image i mentioned and all of the configs that i saved .
Best Regards .
ā07-17-2018 07:36 AM
Please try this way: boot system flash disk0:s72033-adventerprise-mz.151-2.SY7.bin and paste the show bootvar after that.
Best Regards,
ā07-17-2018 07:39 AM
Router(config)#boot system flash disk0:s72033-adventerprise-mz.151-2.SY7.bin
Router(config)#exi
Router(config)#exit
Router#
Router#s
00:24:35: %SYS-5-CONFIG_I: Configured from console by consolehow
Router#show va
Router#show bo
Router#show bootva
Router#show bootvar
BOOT variable =
BOOTLDR variable =
Standby is up
okay now should i copy the running config and reload the router ?
and after that if i saved a list of configurations and reloaded the router how can i be sure that it will be saved
best regards
ā07-17-2018 07:43 AM
Sorry but I can't see that the Boot variable has been set in the last "show bootvar", so is not recomendable to reload after we can find a way to set this properly. Let me see and I will try to get a better option.
Best Regards,
ā07-17-2018 07:45 AM
many thanks diana i'll be waiting
ā07-17-2018 07:59 AM
boot system flash sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin, try this and after send me this outputs:
show run | i boot
show boot
Best Regards,
ā07-17-2018 08:06 AM
Router(config)#$ flash sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin
Router(config)#do show boot
Router(config)#do show boot | i boot
BOOT variable =
BOOTLDR variable =
Standby is up
ā07-17-2018 08:21 AM
Router#show bootvar
BOOT variable = disk0:s72033-adventerprise-mz.151-2.SY7.bin,1;sup-bootdisk:sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin,12;sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin,1;
CONFIG_FILE variable = sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin
BOOTLDR variable =
Standby is up
Standby BOOT variable = disk0:s72033-adventerprise-mz.151-2.SY7.bin,1;sup-bootdisk:sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin,12;sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin,1;
Standby CONFIG_FILE variable = sup-bootdisk:s72033-adventerprise-mz.151-2.SY7.bin
ā07-17-2018 08:30 AM
This is the right output, yes you can reload the device.
Best Regards,
