03-08-2017 04:39 AM - edited 03-08-2019 09:39 AM
Hi folks,
a simple question; i habve a Catalyst 6500 VSS System consisting of two Chassis; each Chassis has
only one Supervisor !
Chassis 1 Supervisor is Hot Standby
Chassis 2 Supervisor is Active
What happens, if Chassis 2 is powered down ? Will Supervisor in Cbassis 1 become active without reloading the switch ?
How long is the traffic disruption time for hosts connected to Chassis 1 ?
Thanks in advance
Manfred
Solved! Go to Solution.
03-08-2017 06:16 AM
If you power down chassis-2 (primary switch), it will take about 3 to 5 seconds before chassis-1 start forwarding traffic. This should be pretty close to seamless for end users.
03-08-2017 06:16 AM
