DHCP Pool to Sub-interface withour IP helper address Possible?
joseluis
Quick Question.
How can I put the DHCP Pool to a specific sub interface without using ip helper address? I would like to try, for example, I have a DHCP Pool configured on my router, but I have many sub interface in my router and I only want my DHCP Pool only to be on VLAN 2? Is that possible? If yes how can I configure that?
Thank you so much!
Julio E. Moisa
It is possible if the DHCP scope is created on the same router where the sub-interface is located  otherwise the ip helper-address is required. A client PC will discover the DHCP server using broadcast.
For example:
ROUTER
interface fa0/0
no shutdown
interface f0/0.2
encapsulation dot1q 2
ip address 192.168.2.1 255.255.255.0
no shutdown
ip dhcp pool VLAN2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 4.2.2.2
ip dhcp excluded-address 192.168.2.1 192.168.2.1
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
