Catalyst 6503 OSPF on Vlan Interface
alex.dersch
Level 4
Level 4
i'd like to configure OSPF on a Catalyst 6503 IOS 12.2.17.
i habe an Gi1/9 with the ip address 192.168.97.30/24 and a VLAN 19 with the IP Address 192.168.19.0/24.
I configured OSPF like this
router ospf 1
network 192.168.97.0 0.0.0.255 area 10.5.0.0
network 192.168.19.0 0.0.0.255 area 10.5.0.0
on the ospf peer is see that the adjaceny is established but i don't get the routes for the 192.168.19.0 network
i checked the ip ospf interface vlan 19; i got ospf is not enabled on the interface
then i tried to configure
int vlan 19
ip ospf 1 area 10.5.0.0
but it does not access ip ospf 1
any other way to solve my problem?
regards
alex
Reza Sharifi
Is vlan 19 in up and up mode? do a "sh ip int bri vlan 19" and check
hi,
here is the show int vlan 19
Vlan19 is up, line protocol is up
  Hardware is EtherSVI, address is 000b.45b0.68c0 (bia 000b.45b0.68c0)
  Internet address is 192.168.19.1/24
and here is the show ip ospf interface vlan 19
show ip ospf int vlan 19
%OSPF: OSPF not enabled on Vlan19
regards
alex
Hi Alex,
Can you try a different area and not 10.5.0.0?
router ospf 1
network 192.168.97.0 0.0.0.255 area 0
network 192.168.19.0 0.0.0.255 area 0
ip ospf 1 area 0
