ā11-28-2018 07:39 AM - edited ā03-08-2019 04:42 PM
9300 series is new to us. Can these switch ports still do 10 Mb ?
ā11-28-2018 08:03 AM
- I tend to doubt it , check the below references :
The Multigigabit ports support PoE and PoE+ for all the supported speeds and cable types. The following table lists the cable types and speed.
Cable Type |
100Mbps |
1G |
2.5G |
5G |
10G |
Category5E |
Yes |
Yes |
Yes |
Yes |
N/A |
Category6 |
Yes |
Yes |
Yes |
Yes |
Yes (55meters) |
Category6A |
Yes |
Yes |
Yes |
Yes |
Yes |
ā11-28-2018 08:08 AM
So it looks like some of the 9300 series switches do? Just not this particular model?
ā11-28-2018 01:46 PM
9300 supported as per document 10/100/1000,( as per document)
