How to configure DHCP system according to mac address
NguyenNgocBa
My system has two switches that act as DHCP (catalyst 3850), I configured the vtp domain down to 6 catalyst 2960x switches underneath the end user, my wifi system uses cisco 2500 contronler.
I have a wifi user but I want him to use only one ip address so I configured the dhcp level according to mac address but there is something wrong he did not receive the ip address as I desired, i also came back Trying to get one on my pc but it does not seem to work either.
I did not know where I was wrong
ip dhcp pool vlan 113
 network 193.168.113.0 255.255.255.0
 default-router 193.168.113.1
 dns-server 11.11.11.11 8.8.8.8
ip dhcp pool test
 host 193.168.113.113 255.255.255.0
 client-identifier 309c.2308.ae1f
 client-identifier IT-113
mac address my device when show up in mac address table of 2 types
309c.2308.ae1f or 0130.9c23.08ae.1f
johnd2310
Level 8
Level 8
Allow the client to connect and check what the client-identifier is. Then use the client-identifier to create a reservation. The client-identifier should be something like 0130.9c23.08ae.1f
John
**Please rate posts you find helpful**
thank you, I was able to handle the error, because the address of the user's mac address saved on the dhcp table, I use the command.
clear ip dhcp binding x.x.x.x
make sure the formatting is correct:
ip dhcp pool test
client-identifier 0130.9c23.08ae.1f
or use the hardware address:
ip dhcp pool test
hardware-address 309c.2308.ae1f
thank you
