Catalyst 9300 switch : FRU power supply B powered off ( Status --- Disabled )
bensonlei
Hi, guys,
We have a Catalyst 9300 switch stack running ( three switches stacking, each switch has two power supplies ); and the devices information as below:
Switch Ports Model SW Version SW Image Mode
* 1 53 C9300L-48T-4X 16.12.4 CAT9K_IOSXE INSTALL
  2 53 C9300L-48T-4X 16.12.4 CAT9K_IOSXE INSTALL
  3 53 C9300L-48T-4X 16.12.4 CAT9K_IOSXE INSTALL
we got alert message of following description last night :
Messages from our monitoring tool:
PROBLEM: Operational status for Switch 3 - Power Supply B, Normal was changed: Shutdown (4) (*UNKNOWN*)
PROBLEM: Operational status for Switch 3 - Power Supply B, Normal is FAILED: Shutdown (4) (*UNKNOWN*)
PROBLEM: Operational status for Switch 3 - Power Supply B, Shutdown is FAILED: Shutdown (4) (*UNKNOWN*)
OK: Operational status for Switch 3 - Power Supply B, Normal was changed: Shutdown (4)
The switch event log:
May 23 04:27:08.607: %PLATFORM_FEP-6-FRU_PS_OIR: Switch 3: FRU power supply B inserted
May 23 04:27:08.608: %PLATFORM_FEP-6-FRU_PS_OIR: Switch 3: FRU power supply B powered off
CLI command shows ( Serial# is modified
SW    PID                               Serial#             Status                    Sys Pwr       PoE Pwr    Watts
3A     PWR-C1-350WAC-P    DyyyyyyyyXL   OK                         Good           n/a             350
3B     PWR-C1-350WAC-P    DyyyyyyyyXE   Disabled                 Bad             n/a             350
Any advice :
1.  Supply problem ?
2.  Switch stack problem ?
3 . IOS issue ?
With many thanks in advance.
Benson LEI
10 Replies 10
Leo Laohoo
  1. Get that power supply replaced
  2. Upgrade the firmware.  16.12.4 is, to put it mildly, not stable.
I can second @Leo Laohoo answer, we are currently running either 16.9.7 or 16.12.5b - both really good so far!
marce1000
 - Also have a visual inspection of the power supply. Usually there is a led-status indicator. Sometimes these messages are due to software bugs. Upgrading to an advisory release is then advised.
 M.
Hi, guys,
Thanks so much for your advices.
The Supply's LED (the red LED) was found flashing while the onsite engineer reached the site, any further recommendation ?
Many thanks
Benson LEI
Upgrade the firmware of your switch or you'll be sorry.
Hi, Leo,
Your recommendation may be correct, according to the articles written in the community.
However,  these bugs have been fixed ( or the one we found ) with the IOS version "Gibraltar-16.12.04"  ??
such as :
1.  bug CSCvn40414.
2.  bug/CSCvo31222
3.  bug/CSCug29756
Many Many thanks
 - The particular power supply is probably broken and needs to be replaced.
 M.
Hi, Marce,
Sure, We shall replace a new supply;
secondly, we also want to confirm it is not a software issue.
So, your guys advices are highly appreciated.
When an appliance is running on the infernal 16.12.4 anything can be "software issue".
 - Usually when it is a software issue, you will get wrong output from the relevant show-commands, but no alarm-indicators on the PS itself.
 M.
