05-08-2020 11:53 AM
Hello for everybody.
I have cat 9300l switch with 16.12.02 ios version.
Switch Ports Model SW Version SW Image Mode
* 1 53 C9300L-48P-4G 16.12.02 CAT9K_IOSXE INSTALL
When I decided to check the status of the ports after upgrading version from 16.11 to 16.12 i saw
Spb-9300#sh int status | i connected
Ap1/0/1 connected 1 a-full a-1000 App-hosting port
Spb-9300#sh run int Ap1/0/1
Building configuration...
Current configuration : 41 bytes
interface AppGigabitEthernet1/0/1
end
What is purpose of this Ap1/0/1 port?
05-08-2020 12:03 PM
The 9300 series switches can also be used as a wireless controller to mange APs.
05-08-2020 05:58 PM
05-09-2020 03:16 AM
Yes, i found only this explanation for the presence of this logical port.
05-09-2020 02:53 PM
yes indeed good question, i have observed too while i am playing with new Code of 16.12.03,
good documentation can be find here :
05-10-2020 02:44 AM
About docker from first link.
I dont remember exactly where, but i saw guides how you can run docker container on modern routers ISR 4000 with
ios-xe, and install full-fledged linux there.
01-31-2023 05:48 AM
if you are not using it, should you disable it?
01-31-2023 07:12 AM
Its up to you, we mostly disable the port.
