Catalyst 9600 Virtial Stack-wise with dual supervisor
AhmedElGarf
Dears,
I have two boxes of 9600 switch and each one of them has two supervisors enginges,
A virtual stack-wise is implemtened as HA between the two boxes.
The case is : when a SUP goes down in the main box , the SUP that goes up is in the second box!
The question is , I need to make the SUP in the same box that having its main SUP failure to take over.
9 Replies 9
Reza Sharifi
What version of software are you running? Usually with traditional VSS, when one sup fails the sup in the other chassis will take over and not the second sup in the same chassis.
brselzer
Hello Ahmed,
At this time, 9600 does not support stackwise virtual with two sups in each chassis:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/software/release/16-12/configuration_guide/ha/b_1612_ha_9600_cg/configuring_cisco_stackwise_virtual.html
"The Cisco Catalyst 9600 Series Switches support Cisco StackWise Virtual with only one supervisor in each chassis."
Hope that helps!
-Bradley Selzer
CCIE# 60833
@brselzer
Good topic and question from me here.....if Cisco has new models and advanced build with many features, what is the status of in-chasis redundancy? ( like old fashion VSS has Quad supervisor support - moving forward to replace 6500/6800 with 96XX as use case ?)
Agreed that old VSS work redundancy as "Z" scenario?
BB
Hello Balaji,
Currently, the 9600s do support in chassis redundancy when they are in standalone mode (not in stackwise virtual). They also support stackwise virtual with a single sup in each chassis. However, at this point they don't support quad-sup (two sups per chassis). I believe quad-sup is on the roadmap.
Does that answer your questions?
Hope that helps!
-Bradley Selzer
CCIE# 60833
Thanks for the clarification, since business look for investment protection..i know Cat 9600 is big investment.
BB
9600 Quadsup should be supported starting 17.1.1
Nothing in release notes of 17.1.1 for quad sup. Anyone got any roadmap info ?
Looks like release notes for 17.2.1 has Quad-Supervisor with Route Processor Redundancy (RPR) listed.
