Packet loss when pinging from/to a cisco 3560e switch
I see Packet loss when pinging from/to a cisco 3560e switch. CPU utilization is normal.
Switches are running with IOS c3560e-universalk9-mz.122-35.SE5.bin.
Packet loss is observed for all the devices irrespective of directly connected or remote devices.
If i do self pinging, there are no packet loss.
I don't see any error on interface.
Can anyone please help me in resolving this issue.
2 Accepted Solutions
Hi Veera,
One more thing you can check if there is any stuck tcp connections.
sh tcp brief
Madhu
This seems to be the issue. This is a lot of them.
And all are to port 49 which is to your TACACS server. I can see only one connection in ESTAB. Can you verify what is that connection?
The simplest way to remove them is clear all at once.
clear tcp tcb *
But it would close down your ESTAB too.. Also your current session and you have to login back.
Else if you have patience you can close them which are in close_wait one by one.
clear tcp tcb 03737C48
clear tcp tcb 039ACDC4 etc...
I am very positive this is going to fix this issue.
Madhu
27 Replies 27
Hi what devices you are trying to ping ?
Do you see any pattern for drops while pinging ?
Thansk,
Madhu
Thanks Madhu for taking up my question.
I am trying to ping directly connected and remote devices like switches(6500)  and computers.
I see ping packet loss from 6500 switch to any 3560e switch but not to other switches like 4500 and 6500.
Here is ping packet drops.
Sending 20, 100-byte ICMP Echos to X.X.X.X, timeout is 2 seconds:
Success rate is 75 percent (15/20), round-trip min/avg/max = 1/1/9 ms
Success rate is 75 percent (15/20), round-trip min/avg/max = 1/3/25 ms
Do you have a large L2 environment?
Could be a STP issue,...
We have L2 environment but i don't see anything which we can suspect that STP is causing the issue. CPU utilization is normal ,no switching loops and traffic on the trunk interfaces is normal. .
Do you see any impact due to this?
Can you ping the hosts connected behind 3560 without loss from 6500?
Madhu
These devices are monitored in solarwinds and because of the icmp packet loss some time device status shown down.
I can ping the host from 6500 without any packet loss but not from 3560.
Hi Veera,
This means there is no problem in packet forwarding at hardware but only control plane is affected(when you ping the switch itself, its handled at software). I am quite not sure why many switches are showing the same behaviour. But what is the uptime of these switches. Probably you may consider reloading one of the switch to see it clears this. Also please share a show tech from one of the switch.
Madhu.
Hi Veera,
sh tcp brief
Madhu
I checked sh tcp brief and most of the TCP connections are in CLOSEWAIT and some of them are in TIMEWAIT and ESTAB.
How many are in CLOSEWAIT. Can you please share the outptut.
That could be one reason for the slow responses.
Madhu.
TCB       Local Address           Foreign Address        (state)
03737C48  10.47.0.229.60053       10.41.81.55.49         CLOSEWAIT
039ACDC4  10.47.0.229.61929       10.41.35.250.49        CLOSEWAIT
03B316C0  10.47.0.229.27544       10.41.81.55.49         CLOSEWAIT
038228F0  10.47.0.229.16506       10.41.35.250.49        CLOSEWAIT
039C3D04  10.47.0.229.15207       10.41.81.55.49         CLOSEWAIT
039A9BD0  10.47.0.229.52983       10.41.81.55.49         CLOSEWAIT
0394152C  10.47.0.229.22425       161.61.35.250.49       CLOSEWAIT
037D811C  10.47.0.229.21117       10.41.81.55.49         CLOSEWAIT
039C12BC  10.47.0.229.37437       10.41.81.55.49         CLOSEWAIT
03933B84  10.47.0.229.34085       161.61.35.250.49       TIMEWAIT
03B32340  10.47.0.229.45729       10.41.81.55.49         CLOSEWAIT
038247D0  10.47.0.229.32816       10.41.81.55.49         CLOSEWAIT
039A92D8  10.47.0.229.38680       161.61.35.250.49       CLOSEWAIT
037370F0  10.47.0.229.13212       10.41.81.55.49         CLOSEWAIT
037D85F0  10.47.0.229.38728       10.41.81.55.49         CLOSEWAIT
03B2B284  10.47.0.229.23428       10.41.81.55.49         CLOSEWAIT
03B2ADB0  10.47.0.229.56836       10.41.81.55.49         CLOSEWAIT
0394BFF0  10.47.0.229.23257       161.61.35.250.49       CLOSEWAIT
036604DC  10.47.0.229.44437       10.41.81.55.49         CLOSEWAIT
0394C700  10.47.0.229.22          192.37.184.211.61639   ESTAB
039B9A68  10.47.0.229.20543       10.41.81.55.49         CLOSEWAIT
03739B28  10.47.0.229.15392       10.41.81.55.49         CLOSEWAIT
0392EA48  10.47.0.229.13862       10.41.81.55.49         CLOSEWAIT
0365E23C  10.47.0.229.27856       10.41.81.55.49         CLOSEWAIT
03817C0C  10.47.0.229.64929       10.41.81.55.49         CLOSEWAIT
039357C8  10.47.0.229.22088       10.41.81.55.49         CLOSEWAIT
037375C4  10.47.0.229.21832       10.41.81.55.49         CLOSEWAIT
039C20E8  10.47.0.229.18169       10.41.81.55.49         CLOSEWAIT
03716D08  10.47.0.229.61993       10.41.81.55.49         CLOSEWAIT
039A74E4  10.47.0.229.62948       10.41.81.55.49         CLOSEWAIT
03655480  10.47.0.229.14052       10.41.81.55.49         CLOSEWAIT
039407F0  10.47.0.229.49643       161.61.35.250.49       CLOSEWAIT
039A53AC  10.47.0.229.13233       10.41.81.55.49         CLOSEWAIT
03739FFC  10.47.0.229.16605       10.41.81.55.49         CLOSEWAIT
039B82B8  10.47.0.229.16458       10.41.35.250.49        CLOSEWAIT
039BEBA4  10.47.0.229.64377       10.41.81.55.49         CLOSEWAIT
03741980  10.47.0.229.13866       10.41.81.55.49         CLOSEWAIT
03B3ABF8  10.47.0.229.19365       10.41.81.55.49         CLOSEWAIT
039B5810  10.47.0.229.24768       10.41.81.55.49         CLOSEWAIT
03956E48  10.47.0.229.55980       161.61.35.250.49       CLOSEWAIT
03946820  10.47.0.229.65053       161.61.35.250.49       CLOSEWAIT
037DBE94  10.47.0.229.15283       10.41.81.55.49         CLOSEWAIT
039A4854  10.47.0.229.48562       10.41.81.55.49         CLOSEWAIT
03B33320  10.47.0.229.29803       10.41.81.55.49         CLOSEWAIT
03B3B79C  10.47.0.229.12142       10.41.81.55.49         CLOSEWAIT
03713C9C  10.47.0.229.63799       10.41.81.55.49         CLOSEWAIT
039BBECC  10.47.0.229.14763       10.41.81.55.49         CLOSEWAIT
03656E40  10.47.0.229.16357       10.41.81.55.49         CLOSEWAIT
0362A73C  10.47.0.229.62450       10.41.81.55.49         CLOSEWAIT
039B878C  10.47.0.229.64402       161.61.35.250.49       CLOSEWAIT
03826CFC  10.47.0.229.16108       10.41.81.55.49         CLOSEWAIT
03B2CA34  10.47.0.229.17634       10.41.81.55.49         CLOSEWAIT
03AD78D0  10.47.0.229.15249       161.61.35.250.49       CLOSEWAIT
03AD967C  10.47.0.229.20389       161.61.35.250.49       CLOSEWAIT
03B2C560  10.47.0.229.37079       10.41.81.55.49         CLOSEWAIT
039C5128  10.47.0.229.24711       10.41.81.55.49         CLOSEWAIT
03822F74  10.47.0.229.54866       10.41.81.55.49         CLOSEWAIT
0372C5FC  10.47.0.229.13298       10.41.81.55.49         CLOSEWAIT
0372D278  10.47.0.229.12407       10.41.81.55.49         CLOSEWAIT
039A33D0  10.47.0.229.36573       10.41.81.55.49         CLOSEWAIT
039BCEF8  10.47.0.229.53853       10.41.81.55.49         CLOSEWAIT
039C02D8  10.47.0.229.53725       10.41.81.55.49         CLOSEWAIT
039B5CE4  10.47.0.229.58027       10.41.81.55.49         CLOSEWAIT
0381866C  10.47.0.229.17100       10.41.81.55.49         CLOSEWAIT
039BB374  10.47.0.229.53148       10.41.81.55.49         CLOSEWAIT
03AD3634  10.47.0.229.19716       161.61.35.250.49       CLOSEWAIT
0362DAA4  10.47.0.229.19479       10.41.81.55.49         CLOSEWAIT
0365AE60  10.47.0.229.62209       10.41.81.55.49         CLOSEWAIT
0362D5D0  10.47.0.229.41327       10.41.81.55.49         CLOSEWAIT
037D7C48  10.47.0.229.58283       10.41.81.55.49         CLOSEWAIT
03955474  10.47.0.229.33810       161.61.35.250.49       CLOSEWAIT
0373B15C  10.47.0.229.23331       10.41.81.55.49         CLOSEWAIT
036628D0  10.47.0.229.46856       10.41.81.55.49         CLOSEWAIT
03819584  10.47.0.229.19861       10.41.81.55.49         CLOSEWAIT
0394D000  10.47.0.229.64732       10.41.35.250.49        CLOSEWAIT
0394B760  10.47.0.229.19967       161.61.35.250.49       CLOSEWAIT
039B6BD4  10.47.0.229.40096       10.41.81.55.49         CLOSEWAIT
03AD7150  10.47.0.229.65184       10.41.35.250.49        CLOSEWAIT
039BC3A0  10.47.0.229.64702       10.41.81.55.49         CLOSEWAIT
03B3A724  10.47.0.229.60399       10.41.81.55.49         CLOSEWAIT
037145E0  10.47.0.229.43951       10.41.81.55.49         CLOSEWAIT
03955EDC  10.47.0.229.29015       161.61.35.250.49       TIMEWAIT
0365FB34  10.47.0.229.13961       10.41.81.55.49         CLOSEWAIT
03828D54  10.47.0.229.12743       10.41.81.55.49         CLOSEWAIT
037DB40C  10.47.0.229.23708       10.41.81.55.49         CLOSEWAIT
039AF814  10.47.0.229.15100       10.41.81.55.49         CLOSEWAIT
0392E344  10.47.0.229.23399       10.41.35.250.49        CLOSEWAIT
0393DC3C  10.47.0.229.15393       161.61.35.250.49       CLOSEWAIT
03AD85D0  10.47.0.229.40932       161.61.35.250.49       TIMEWAIT
039574CC  10.47.0.229.25935       10.41.35.250.49        CLOSEWAIT
03738B74  10.47.0.229.58656       10.41.81.55.49         CLOSEWAIT
039AD91C  10.47.0.229.56760       10.41.81.55.49         CLOSEWAIT
03B3BC70  10.47.0.229.15058       10.41.81.55.49         CLOSEWAIT
03B2DC54  10.47.0.229.51131       161.61.35.250.49       CLOSEWAIT
03B393F0  10.47.0.229.11957       10.41.35.250.49        CLOSEWAIT
039B2610  10.47.0.229.33728       10.41.81.55.49         CLOSEWAIT
03B311EC  10.47.0.229.18047       10.41.81.55.49         CLOSEWAIT
039A8E04  10.47.0.229.52022       161.61.35.250.49       CLOSEWAIT
0365D460  10.47.0.229.12241       10.41.81.55.49         CLOSEWAIT
03B33E78  10.47.0.229.47640       10.41.81.55.49         CLOSEWAIT
0372C128  10.47.0.229.60323       10.41.81.55.49         CLOSEWAIT
03661CD8  10.47.0.229.39923       10.41.81.55.49         CLOSEWAIT
0393C73C  10.47.0.229.41864       10.41.35.250.49        CLOSEWAIT
03829584  10.47.0.229.56673       161.61.35.55.49        CLOSEWAIT
0362AC10  10.47.0.229.31952       10.41.81.55.49         CLOSEWAIT
039BF078  10.47.0.229.22636       10.41.81.55.49         CLOSEWAIT
0365CF8C  10.47.0.229.14476       10.41.81.55.49         CLOSEWAIT
039B443C  10.47.0.229.59226       10.41.81.55.49         CLOSEWAIT
0393E794  10.47.0.229.56282       10.41.35.250.49        CLOSEWAIT
03657740  10.47.0.229.25769       10.41.81.55.49         CLOSEWAIT
03B2F6E8  10.47.0.229.19328       10.41.81.55.49         CLOSEWAIT
0373AC88  10.47.0.229.25766       10.41.81.55.49         CLOSEWAIT
039B213C  10.47.0.229.28882       10.41.81.55.49         CLOSEWAIT
039C07AC  10.47.0.229.38201       10.41.81.55.49         CLOSEWAIT
03AD8DD0  10.47.0.229.23002       10.41.35.250.49        CLOSEWAIT
03739048  10.47.0.229.29572       10.41.35.250.49        CLOSEWAIT
039BA464  10.47.0.229.32273       10.41.81.55.49         CLOSEWAIT
03B31E6C  10.47.0.229.32521       10.41.81.55.49         CLOSEWAIT
0365EBE0  10.47.0.229.41319       10.41.81.55.49         CLOSEWAIT
03938804  10.47.0.229.62841       10.41.35.250.49        CLOSEWAIT
039A1AF8  10.47.0.229.12758       10.41.81.55.49         CLOSEWAIT
039B7DE4  10.47.0.229.20921       10.41.81.55.49         CLOSEWAIT
036549F8  10.47.0.229.51903       10.41.81.55.49         CLOSEWAIT
03714CC8  10.47.0.229.45145       10.41.81.55.49         CLOSEWAIT
037425F8  10.47.0.229.56492       10.41.81.55.49         CLOSEWAIT
03B39D74  10.47.0.229.18174       10.41.81.55.49         CLOSEWAIT
clear tcp tcb *
Madhu
A likely hit  of the bug
https://tools.cisco.com/bugsearch/bug/CSCub04965/?reffering_site=dumpcr
Note : Kindly rate helpful posts
Madhu
Thanks Madhu , It should resolve my issue.I 'll try and let you know.
