Catalyst C1300-24XT IP Helper Address Procedure
iamroy
I am trying to setup an IP HELPER-ADDRESS per SVI but clients are not getting IP address from the assigned DHCP Server in the IP HELPER Address.  C1300-24XT has also different syntax or argument in declaring IP HELPER-ADDRESS.
Catalyst 1300 Series Managed Switch, 24-port 10GE, 4x10G SFP+
System Object ID: 1.3.6.1.4.1.9.1.3250
Does any here could share the correct procedure for this? Thank you.
iamroy
Solution:  USE DHCP RELAY.
1.Remove Local DHCP Server
no ip dhcp server enable
2.Enable DHCP Relay Globally
ip dhcp relay enable
3.Configure each VLAN Interfaces to enable ip dhcp relay
4. Define DHCP Server IP Globally
ip dhcp relay address (External DHCP Server IP)
5. Remove Legacy ip helper-address
no ip helper-address all
6. Verify Configuration
show ip dhcp relay
26 Replies 26
@iamroy hi, can you share the configuration you did as of now?
Good luck
KB
iamroy
iamroy
Please disregard the previous config file. My apologies. Attached is the correct one.
iamroy
@iamroy hi, i see you have DHCP configured in switch. but helper address pointing to the IP range which is not inside the switch. can you explain the setup bit? such as are you using switch as a dhcp server or is there any separate dhcp server? is this helper address reachable to switch? do you have routes in place to reachability?
Good luck
KB
The CORE switch (10.0.1.254/24) has multiple VLANs (4, 6, 8, 16).
An external Windows DHCP server (10.0.1.250/24) is configured and reachable from the switch and all devices.
The  external Windows DHCP server, is successfully assigns IPs to VLANs on the same network of CORE switch ONLY but not on other VLANS.
Currently, the CORE C1300(10.0.254) device is handling DHCP for VLANs 6, 8, and 16.
All routing is in place, and there's full reachability between the switch, DHCP server, and clients.
@iamroy hi, is this happening to the clients who connected to access switch terminated to port interface TenGigabitEthernet1/0/21? or all access switches?
Good luck
KB
balaji.bandi
ip helper-address all 10.0.1.250 37 42 49 53 137 138
you already have all VLAN helper address.
enable ip routing
default-gateway means in normal cisco world just act as layer 2 switch, so try enable ip routing with ip route command to route and check, below CLI guide for reference.
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli/ip-routing-protocol-independent-commands.html?bookSearch=true#wp2483733251
still issue post below output :
show vlan
show ip interface brief
show ip route
show ip helper-address
BB
Routing is enabled and inter vlan connectivity is working.
DentalCore#show interfaces status
Flow Link Back Mdix
Port Type Duplex Speed Neg ctrl State Pressure Mode
te1/0/1 10G-Copper Full 1000 Enabled Off Up Disabled Off
te1/0/2 10G-Copper Full 1000 Enabled Off Up Disabled On
te1/0/3 10G-Copper -- -- -- -- Down -- --
te1/0/4 10G-Copper -- -- -- -- Down -- --
te1/0/5 10G-Copper -- -- -- -- Down -- --
te1/0/6 10G-Copper -- -- -- -- Down -- --
te1/0/7 10G-Copper -- -- -- -- Down -- --
te1/0/8 10G-Copper -- -- -- -- Down -- --
te1/0/9 10G-Copper -- -- -- -- Down -- --
te1/0/10 10G-Copper -- -- -- -- Down -- --
te1/0/11 10G-Copper -- -- -- -- Down -- --
te1/0/12 10G-Copper -- -- -- -- Down -- --
te1/0/13 10G-Copper -- -- -- -- Down -- --
te1/0/14 10G-Copper -- -- -- -- Down -- --
te1/0/15 10G-Copper -- -- -- -- Down -- --
te1/0/16 10G-Copper -- -- -- -- Down -- --
te1/0/17 10G-Copper -- -- -- -- Down -- --
te1/0/18 10G-Copper -- -- -- -- Down -- --
te1/0/19 10G-Copper -- -- -- -- Down -- --
te1/0/20 10G-Copper -- -- -- -- Down -- --
te1/0/21 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
te1/0/22 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
te1/0/23 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
te1/0/24 10G-Combo-C Full 1000 Enabled Off Up Disabled On
DentalCore#show vlan
Created by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN, V-Voice VLAN
Vlan Name Tagged Ports UnTagged Ports Created by
1 1 te1/0/19-24 te1/0/11-18 D
4 mgt te1/0/13-18 te1/0/1-6, S
te1/0/19-24
6 server te1/0/13-24 S
8 faculty te1/0/13-24 te1/0/7-8 S
16 student te1/0/13-24 te1/0/9-10 S
DentalCore#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static,
R - RIP
S 0.0.0.0/0 [1/4] via 10.0.1.253, 151:10:22, vlan 4
C 10.0.1.0/24 is directly connected, vlan 4
C 10.0.8.0/21 is directly connected, vlan 8
C 10.0.16.0/20 is directly connected, vlan 16
C 192.168.6.0/24 is directly connected, vlan 6
DentalCore#show ip helper-address
Interface Helper Address Udp port
All 10.0.1.250 37,42,49,53,137,138
how is this switch connected to uplink - what port ?  where is DHCP Server located  ? does other network know return path for other IP address ?
post -
BB
C1300 is the CORE Switch.  The UPLINK ports of other Access Switches are connected to port21 to 24 of C1300 CORE Switch.
The Windows DHCP server is connected to port2 of the CORE Switch.
Command "show ip interface brief" is not applicable to this model, instead  the equivalent command is "show interface status"
DentalCore#show ip interface brief
% Wrong number of parameters or invalid range, size or characters entered
DentalCore#
Looking at the configuration attached. port 21-24 (trunk and have native VLAN 4) and 21 configured access VLAN 4 (so that allow only VLAN 4) - so make sure you check the port 21 and test again.
for testing purpose - can you connect device to below ports on this switche and check is the DHCP offerning any IP :
interface TenGigabitEthernet1/0/6
switchport access vlan 4
interface TenGigabitEthernet1/0/7
switchport access vlan 8
interface TenGigabitEthernet1/0/9
switchport access vlan 16
Note : i  know some of the syntax not work on these model, just want to check is the SVI vlan 6, 8 and 16 are up ?
BB
Yes, same issue setting Access Ports with different VLANS on those mentioned ports of C1300.  Clients are getting IP from C1300 and not the Windows DHCP Server.
Tried removing the DHCP pools in the C1300 Switch and clients in VLAN 6,8,16 are unable to get IP address.
Ports configured as Access Ports VLAN4 are getting IP from the Windows DHCP server.
Try disabling DHCP Server and test - if possible run debug and check DHCP relay working.
Since its working only for Native VLAN 4 not others.
BB
