Catalyst C9300, card C9300-NM-8X, gbic SFP-10G-T-X
nicolas.sandraz
Hello every body,
I have this setup (object of this post), but i can't use 10G copper connexion to my computer.
Every time i used a TenGigabitEthernet1/0/X (with X 1 to 8), the interface go down with err-disabled on "sh interface".
The message is
gbic-invalid error detected on te1/1/X, putting Te1/1/X in err-disabled
Does this gbic is not supported on this additional module? If yes, wich gbig i have to used for a 10G connexion on copper link?
Best regards,
Nicolas
C9300 version 17.03.03
7 Replies 7
balaji.bandi
what is the Full model of Cat 9300 switch. is this  SFP-10G-T-X From cisco or 3rd party ?
check module support :
https://tmgmatrix.cisco.com/?si=SFP-10G-T-X
if it is 3rd party  try below :
(config)#service unsupported-transceiver
(config)#no errdisable detect cause gbic-invalid
BB
Hi Balajy Bandi,
My catalyst is a C9300-48P-E, the gbic i used if a real Cisco gbit
SFP-10G-T-X (SN : MTC25190D8E witch Cisco stiker).
With the both commands there is no change, I can't use my gbic to make a
10G connexion. When i plug it on my module, the message
"%PLATEFORM_PM-6-MODULE_ERRDISABLE : The inserted SFP module with interface
name Te1/1/X is not supported".
But now the interface status is no more "err-disabled", but "notconnect".
So is there a Gbic with copper media compatible to the C9300-NM-8X module?
Best regards,
Nicolas
All ports in the C9300-NM-8X module default to 10 G  - so technically should support cisco SFTP ( I have not tested 10GB copper SFP)
Can you post
show interface ten 1/1/X trans details
I would like to see if the SFP recognised.
if the SFP recognised, try no negotiation can results any success (this is for testing - this is not solution)
speed nonegotiate
BB
Message i have after i plugin the gbic :
*Sep 24 20:11:39.849: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP
module with interface name Te1/1/8 is not supported
c9300#sh interfaces tenGigabitEthernet 1/1/8 transceiver detail
Diagnostic Monitoring is not implemented
Diagnostic Monitoring is not implemented.
TenGigabitEthernet1/1/8 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 00b1.e31b.d03c (bia
00b1.e31b.d03c)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is unknown
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
After I plug my computer to this gbic, I have the same responses from the
previous command.
Best regards,
Nicolas
SFP-10G-T-X  - I believe your model not support i guess here as per the below message. But wait for anyone used this module and can comment.
as per the matrix it only support only 1 model, so your model not in the list for sure.
BB
Seb Rupik
Hi there,
You need to upgrade your software version to at least 17.6.1
cheers,
Seb.
According to compatibility guides, SFP-10G-T-X is not officially compatible with C9300-NM-8X module. check below links. this module supports up to 1G copper transceivers GLC-TE and if you need to use 10G, it only support fiber transceivers.
https://tmgmatrix.cisco.com/?npid=670 -  module's transceiver compatibility list
https://tmgmatrix.cisco.com/?tpid=961 - transceiver's compatibility list
rate this and mark as answer if this resolved your concern
Good luck
KB
Good luck
KB
