Catalyst Compact Flash Card
Brian Dean
Community Member
Will the 512MB Compact Flash Card part number 16-3397-01 work in the Cisco 6509 ?
Collin Clark
Chad,
That should work fine. You may have to format the card if it came from another platform like a router.
Hope it helps.
Collin Clark
Chad,
Hope it helps.
Thanks Collin!
Maximum size of the CF (third party) is 2Gb.
