catalyst ie3000 and autoinstall / update firmware
Monique MANI
I try to use the autoinstall feature of the catalyst IE3000 to push a IOS image when it's fresh.
The dhcp server is configured to send the tftp server address and image filename (with the option 125).
The switch download right the filename (the name is autoinstall_dhcp)  from the tftp server but failed to extract it, after that he's try to get
a directory (ies-lanbasek9-mz.122-58.SE2/) on the tftp server :
*Mar  1 00:01:38.297: AUTOINSTALL: Vlan1 is assigned 10.1.22.10 got vend id vend spec. info ret: succeed
*Mar  1 00:01:48.305: AUTOINSTALL: Obtain tftp server name 10.1.22.225 resolved to 10.1.22.225
Loading autoinstall_dhcp from 10.1.22.225 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 18042880 bytes]
Could not buffer tarfile...using multiple downloads
examining image...
%Error opening tftp://10.1.22.225/ies-lanbasek9-mz.122-58.SE2/ (Timed out)
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
*Mar  1 00:04:25.415: AUTOINSTALL: Error (1) Image is not a valid IOS image archive or not existing
Any ideas ?
Many thanks for any help or tips
IE3000#sh ver
Cisco IOS Software, IES Software (IES-LANBASE-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 18:52 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is Xmen2 boot loader
BOOTLDR: IES Boot Loader (IES-HBOOT-M) Version 12.2(44r)EX5, RELEASE SOFTWARE (fc1)
IE3000 uptime is 1 hour, 38 minutes
System image file is "flash:/ies-lanbase-mz.122-55.SE3/ies-lanbase-mz.122-55.SE3.bin"
cisco IE-3000-8TC (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1532Y40B
Last reset from power-on
1 Virtual Ethernet interface
16 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:08:30:3C:7B:80
Motherboard assembly number     : 73-10855-10
Motherboard serial number       : FOC15310TSG
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : IE-3000-8TC
System serial number            : FOC1532Y40B
Top Assembly Part Number        : 800-28538-01
Top Assembly Revision Number    : K0
Version ID                      : V01
CLEI Code Number                : COMVH00ARA
Hardware Board Revision Number  : 0x02
CIP Serial Number               : 0x7B80464F
SKU Brand Name                  : Cisco
Switch Ports Model              SW Version            SW Image
*    1 18    IE-3000-8TC        12.2(55)SE3           IES-LANBASE-M
Configuration register is 0xF
amikat
In my view when doing autoinstall with image update for ie3000 you should have both the image (tar) file (ies-lanbasek9-mz.122-58.SE2.tar) and the text file pointing to image file (autoinstall_dhcp) at the tftp server. So your "autoinstall_dhcp" text file just need to correctly specify the path to the image file (including the directory) at the tftp server. Will you please check that.
Best regards,
Antonin
5 Replies 5
ankugarg
Level 3
Level 3
Hi Monique,
Make sure that you are using the tar image.Also try deleting "update" directory in flash if any before you begin the upgradation.
What are you using as tftp server?It looks like a tftp server problem.
amikat
Best regards,
Antonin
Leo Laohoo
If memory serves me correct, Zero-Touch is not supported on the IE3000.
Have a look on this documented attached if this is what you are looking for.
Auto install and zero touch smart install are different features.Zero touch smart install doesn't work on IE,but i think auto install is supported.
Monique MANI
Thanks you very much sirs
After put the name of the image filename on the file "autoinstall", he load it correctly
