built a stack WS-C3750X-24S-E and WS-C3750X-24T-L
Jan Krcmar
Dear all.
We have a problem with a stack // two switches.
WS-C3750X-24S-E  &  WS-C3750X-24T-L
Both switches have the same IOS.
WS-C3750X-24S-E
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       15.0(1)SE             C3750E-UNIVERSALK9-M
WS-C3750X-24T-L
*    1 30    WS-C3750X-24S      15.0(1)SE             C3750E-UNIVERSALK9-M
The reason for the problem is different major version
*Mar  1 00:00:25.358: %STACKMGR-5-MAJOR_VERSION_MISMATCH: Major Version Mismatch (Local 1 - Received 6) with neighbor-0
*Mar  1 00:00:25.358: %STACKMGR-5-MAJOR_VERSION_MISMATCH: Major Version Mismatch (Local 1 - Received 6) with neighbor-1
WS-C3750X-24S-E
Switch   Master/   Mac Address          Version    Current
Number   Member                          (maj.min)  State
1        Master    0007.7d3c.b280          1.46        Ready
WS-C3750X-24T-L
1        Master    44d3.ca7d.1000          6.46        Ready
How can we upgrade the WS-C3750X-24S-E to the same major version??
Thanks in advance for your help.
Jan
Leo Laohoo
Firstly, stay away from 15.0(1)SE IOS.  It's got a memory leak like you can't imagine.
Try to use the 12.2(58)SE2 and see if you have the same issue.
Another thing, I believe one of your switch's product code ends with an "L".  I believe this model has an IP Base License while the other model with the "E" has a higher license and this could be the issue.
Can you please post the complete output for the command "sh license".
Hi.
you are right.
the WS-C3750X-24T-L
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
and the WS-C3750X-24S-E
I found now -->
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
The Cisco Catalyst 3750-X Series Switches with LAN  Base feature set can only stack with other Cisco Catalyst 3750-X Series  LAN Base switches. A mixed stack of LAN Base switch with IP Base or IP  Services features set is not supported.
Do you know ... if we upgrade the LAN Base to IP Base on the WS-C3750X-24T-L. Will the stack work?
Thanks.
Yes, it will work.. All the other switches in stack should have the same ip base license and IOS
I have attached a document for your reference.
Hope this helps
Cheers
Somu
Rate helpful posts
SunilKhanna
Hi Jan,
Here is a URL for upgrading an IOS on 3750 stack. Hope you find it useful when urgrading the IOS
Catalyst 3750 Software Upgrade in a Stack Configuration with Use of the Command-Line Interface
Sunil
Regards, Sunil Khanna
