Catalyst WS-C3650-48PD switch not passing DHCP info to PCs on ports 24-48
Damon Williams
I have an unique issue after configuring a 3650 switch setup as an access Layer 2 switch. For some odd reason nodes (PCs, laptops) are able to receive their DHCP IP info on ports 2-24 with no issue but not on ports 25-48. The trunk port is on port 1 (g1/0/1) which is connected to another access Layer 2 switch. The latter switch is connected to the core switch.
Vlan 212 is the data vlan and vlan 213 is the voice... both vlans are configured on ports 2-48 and the trunk is passing the vlans to it. I know for a fact the DHCP pool subnets for vlan 212 & 213 (10.210.2.0/24 & .3.0/24) are not used up so why would the devices not receive the IP info? Any device connected on ports 2-24 on vlan 212 & are able to reach internet. Anybody has a solution this?
Below is the configuration
version 15.0
no service pad
service password-encryption
service compress-config
boot-start-marker
boot system switch all flash:packages.conf
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered informational
logging console informational
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization network default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
clock timezone AR -3 0
switch 1 provision ws-c3650-48pd
no ip domain-lookup
ip device tracking
table-map AutoQos-4.0-Trust-Cos-Table
default copy
diagnostic bootup level minimal
spanning-tree mode pvst
redundancy
mode sso
ip ssh version 2
class-map match-any non-client-nrt-class
match non-client-nrt
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
switchport access vlan 212
switchport mode access
switchport voice vlan 213
spanning-tree portfast
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan211
ip address 10.210.1.11 255.255.255.0
no ip redirects
no ip route-cache
ip default-gateway 10.210.1.1
ip http server
ip http authentication local
no ip http secure-server
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps port-security
snmp-server enable traps entity
snmp-server enable traps config-copy
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
tacacs-server host 10.208.93.24
tacacs-server directed-request
tacacs-server key 7 06110E33404B1D14001E1C
line con 0
exec-timeout 30 0
logging synchronous
stopbits 1
line aux 0
exec-timeout 30 0
logging synchronous
stopbits 1
line vty 0 4
exec-timeout 30 0
length 0
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
ntp peer 10.208.87.23
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
saarbue5flsw1#
9 Replies 9
Philip D'Ath
What software version are you running on your switch?
SW. Ver: 03.03.05SE
SW Image: cat3k_caa-universalk9
That is not a good release of code.  Before you do any further investigation upgrade to  3.6.4E.
https://software.cisco.com/download/release.html?mdfid=284850605&softwareid=282046477&release=3.6.4E&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Hi Philip,
In case this issue may occur again, the 3650 switch had an issue with one of it's ASICs that has been documented for the C3850-48P switch. Unfortunately there was no work around for the C3650-48P except having Cisco replace the switch via RMA. Upgrading the IOS to the recommended version or latest version did not fix the problem. Below are the detailed symptoms from Cisco:
Traffic not forwarding on access ports on one ASIC, while Mac&ARPareLearn
CSCux39091
Description
Symptom:
A WS-C3850-48P may not forward packets out of the ports associated with either forwarding ASIC 1 (port 1-24) or forwarding ASIC 0 (ports 25-48). During the packet loss the EGR_MISC_FATAL_ERROR counter increments in the "show controllers ethernet-controller port-asic statistics exceptions switch {switch#}” command output for the effected ASIC
Conditions:
The issue can be seen if the switch is doing L3 or L2 forwarding. MAC and ARP table entries are complete
The issue has been seen until now on a WS-C3850-48P running 3.3.5 and 3.3.0
Workaround:
The issue was resolved after an upgrade to 3.6.3. It is unclear at this point whether the code upgrade or the switch reload fixed the issue
Further Problem Description:
Customer Visible
Add Notification
Save Bug
Open Support Case (0)
Details
Last Modified:
Jun 4,2016
Status:
Terminated
Severity:
2 Severe
Product:
(1)
Cisco Catalyst 3850 Series Switches
Known Affected Releases:
(1)
n/a
Known Fixed Releases:
(0)
No release planned to fix this bug
johnd2310
Level 8
Level 8
Have you tried defaulting interfaces 25-48 and reapplying the config to these ports?
John
**Please rate posts you find helpful**
Hi John,
I removed the commands under ports 25-48 and reapplied them. The issue still occurred
Have you tried the software upgrade I recommended?  I wouldn't waste time doing much else until that is done.  You are not using a good version of code.
Yep I updated the software version. I'm still having the same issue.
This is the only access layer 2 switch not directly connected to the core switch. There's a trunk going to an access switch to get to the core switch. Apparently this is the only switch having this issue.
You just triggered something in my memory - core switch.  I assume the core switch is where the DHCP server is?
Any chance the core switch has DHCP snooping or something else configured which might be blocking this?
