Catalyst WS-C3850-48XS-E Stackwise virtual link with 40g uplinks
Good Morning,
For the Catalyst WS-C3850-48XS-E I would like to know if I configure two, of the 4 available, 40g interfaces  for the Stackwise Virtual Link, Can the remaining two be used for normal network connections ?
In short, the use of two 40G interfaces for S.V.L. does not limit the possibility of using the other two available for networks uplinks ?
Thnx
Bye
2 Accepted Solutions
brselzer
That is correct. You can use two for stackwise virtual and the other two for general purpose. You can not use the uplinks for dual active detection:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-6/configuration_guide/b_166_stck_mgr_ha_3850/b_166_stck_mgr_ha_3850_chapter_010.pdf
Hope that helps!
-Bradley Selzer
CCIE# 60833
nazimkha
brselzer
Hope that helps!
-Bradley Selzer
CCIE# 60833
nazimkha
Thnx very much for tour cooperation
Bye
