Trouble connecting to C2960 switch via Cisco Network Assistant
hstone4
I have two Catalyst 2960 switches that are part of an inherited network and I am trying to get them connected to Cisco Network Assistant so I can easily backup the config before changing some settings on one of the ports.  Both switches are model WS-C2960-48PST-S running IOS 12.2.  I've enabled the http server using "ip http server" and also ran "ip http authentication local".  I can ping the switch from the server i'm running CNA on, but when I try to connect I get the error "Unable to connect".  I'm using CNA version 5.5
5 Replies 5
I tried with version 6.3.3 and got the same error.
Are you running Rrlease 12.2.55-SE12 MD ?
When I run "show version" it tells me I have "Version 12.2(50)SE3, REL" next to Cisco IOS Software.  Do I need to upgrade to 12.2.55-SE12?
Give that a try, it is the recommended release to work with CNA...
