08-29-2007 10:42 AM - edited 03-05-2019 06:10 PM
Where can I find information on up-to-date software images for both CatOS and IOS? I would like to be able to compare the features to what we have now and then buy.
Solved! Go to Solution.
08-29-2007 11:14 AM
Please use Cisco Feature Navigator to find information about Cisco IOS software images and the supported features for your platform(s) :
HTH,
Mohammed Mahmoud.
08-29-2007 11:14 AM
HTH,
Mohammed Mahmoud.
08-29-2007 03:38 PM
Catos is just about out the door , its all over but the shouting . Hate to see it myself i always found catos once you learned it a lot easier to get things done with the simpler "set" commands . Just my opinion but i bet you will see an announcement in the not too distant future about catos EOL/EOS .
