Catos command to show fautly fan part id
Tony Bilton
Hello all,
I need to replace a faulty fan unit on the catos WS-6509 switch. It's confirmed by the show env all command.
this Catos switch does not support show inventory so any other catos commands which will show me this part id?
Tony.
glen.grant
  I don't  think there is a catos command for that .    You probably going to have to have someone pull it and get the part number.     The fan was about the only part you could not get with a show module  command or show system .
mahmoodmkl
Level 7
Level 7
What catos code u r running.
The show inventory command is supported on 8.3 and u can get the serial no info from it.
