02-04-2022 02:42 PM
I just got this CBS220-24T-4G approx. 1 month ago. I saw them restarting by its own a couple of times since then. I tried to figure how to open a support case with CISCO but I failed to find out how. So, anyone out there who has got an idea what I could do or maybe has got the same problem with this device (family)?
I'm running the latest firmware which is 2.0.1.9 but saw this to happen with earlier versions as well.
Best,
dialsc
02-04-2022 02:59 PM
We are not sure what is the reason here,
Maybe check the power blips, or grounding, or an earthing issue?
what is the logs show ?
here is TAC numbers to reach :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
02-04-2022 03:03 PM
The switch is connected to an UPS just as all the other equipment. No issue here I guess.
There is nothing in the logs as far as I see. But I just enabled Flash Memory logs. Maybe somethings' in there after the next auto-restart.
02-24-2022 09:23 AM
I tried to get in contact with TAC support but beside waiting in the queue nothing happens for 30 minutes...
I do see in the logs, I did activate the flash logs, that the switch initiates a reboot by its own. Looks like an ordinary reboot. There is nothing like a reason for it logged before, just this out of nothing: %SYSTEM-4-REBOOT: System reboot
Then it runs through the reboot...
Could that just be a faulty device, memory or something like that?
BTW: Getting in touch with support at Cisco is one of the toughest things I had to go through since years!
02-24-2022 11:41 PM
- Use a syslog-server for log monitoring on continuous basis , perhaps more indicators can be seen as to why the device has a problem.
M.
02-25-2022 07:32 AM
I did so and there is nothing in the logs sent to the syslogServer showing a reason for the reboot, even not on debug level. Just: REBOOT!
02-25-2022 07:43 AM
- Save configuration to external device. Then in Administration , select Restore to Factory Defaults - Restore configuration afterwards, check if that can make the device more stable.
M.
02-25-2022 08:03 AM
Done. Let's see what happens...
04-08-2022 01:10 PM
So, I did reset to factory defaults and re-applied the configuration, same result, random reboots. I also set the syslog settings to debug and just before the switch reboots this gets logged: Level = Warning, Message = %SYSTEM-4-REBOOT: System reboot
Nothing else, the switch then reboots.
I also RMA'd the switch and got it replaced. After upgrading to the latest firmware and re-applying the configuration I'm facing the same problem.
SO: What the heck, how do I get support from CISCO? Is it just me not getting it or is it true that I can buy CISCO switches regularly but I do not get any kind of support until I pay again? What happened to CISCO? I remember times when CISCO valued me to be a customer buying their products and providing me support once I was facing a problem. I'm really upset!
09-03-2024 09:43 PM
Hi dialsc,
This looks like a problem on their small business line up to me. I don't know what did they do, but they might have done some regular restart on their small business series. both of my CBS AP experience reboot at night 2AM at the same time or sequentially. despite of being a home user, the fact that its actually a business oriented product make it unacceptable. Not to mention that one of the AP failed and as I brought it from amazon, I failed to perform RMA from Cisco with it. I would like to know if the issue persist into the latest CBS software version.
Peter Wan
09-03-2024 09:48 PM
Dear dialsc,
I have found this on the internet. seems like its some sort of firmware fault that system 4 is referring to.
Best Regards,
Peter
10-30-2022 12:11 AM
Hello
No solution?
I also bought this CBS220 Switch an had no trouble until I update to the newes Version 2.0.1.9
After I could see the random restarts at least once a day. In the log I only could see the system has restarted.
Last week I switch back to the last Version 2.0.1.5 (Administration/File Management/Firmware Operations->Swap Image) and now I don't have restarts anymore!
Software Information | |
Firmware Version (Active Image) | 2.0.1.5 |
Firmware MD5 Checksum (Active Image) | cf98472b20fc26d223b0f2313d9b1839 |
Firmware Version (Non-active) | 2.0.1.9 |
Firmware MD5 Checksum (Non-active) | a190eaa7b123e7ab73c386604eba175c |
Boot Version | 1.0.0.17 |
Locale | ja-JP |
Language Version | 2.0.0.11 |
Locale | zh-CN |
Firmware 2.0.1.9 pretty sure buggy !
BR, Horst
11-10-2023 10:01 PM
01-08-2025 06:45 PM
I'm curious if you have resolved the issue. I'm also experiencing the same problem and finding it challenging.
