CBS220 Firmware Update not working
colorTV
My CBS220 shows active firmware 2.0.0.13 and the non-active firmware is a higher version. When I reboot, the switch would stay on the 2.0.0.13. I actally tried all four versions from cisco.com with the same result.
Does anyone have an idea what else I should try or how to debug this?
Take a look in "Administration > File Management > Firmware Operations"
Try to find something like Swap Image
Older switches and switches with CLI only, you can boot from a specific image on the flash. Those new switch is a bit different but at the end is all the same.
Oh boy, Thanky you very much. I know this function very well, but I haven't seen it on the CBS series. But as you say: at the end is all the same.
I had however two smaller CBS220 Switches whicht automatically swapped the image. I only had to reboot after uploading the firmware. But the FW was 2.0.1.5 to begin with.
balaji.bandi
To understand better can you post some screenshots here or follow the below guide :
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2524-upgrade-firmware-web-ui-switch.html
BB
