Help stacking 2 SG500XG-8F8T 16-Port 10GB managed switches
EduardoRuiz
I need assistance on how to properly stack these 2 switches together. Both switches were reset to factory settings and upgraded the firmware to the latest version available.
I have tried but have failed to get them to work as 1. Here's what I have done;
Unit 1
IP Static: 192.168.2.91
Stack Master: Set as Unit1
Stack Mode: Native Stacking
Stack connection speed: 10G
XG15 and XG16 were selected as the stacking ports
Unit 2
IP Static: 192.168.2.92
Stack Master: Set as Unit 2
Unit 2 Stack Connection Speed: 10G
Did I miss a setting? It looks pretty straightforward but yet I can't get this to work.
Help.
These settings seem to be fine but when I connect the cable in the ports to make the units stackable, unit 2 restarts and all the lights in the front turn on and stay in that state. Please see the screenshot attached.
Hello
The switchs do not require separate ip addresses so to make sure the switches are set t default and have no stacking enabled, So disconnect the stack cabling and log on to each switch individually
sw1 -s2
conf t
no stack config
exit
wr mem
reload
once switches have reloaded
sw1
config t
stack unit 1
stack config link x/x-x unit-id 1
end
wr me
reload
sw2
config t
stack unit 1
stack config link x/x-x unit-id 2
end
wr me
power off
Connect stack cables between sw-2
power up sw2
once both switches are up, console onto sw1
show stack config
Kind Regards
Paul
hard to say what you are missing. Which ports and which cable are you using to form the stack ?
Maybe looking at the short video below helps:
https://www.youtube.com/watch?v=HWJgM2Bkxf8
An easy how to video on how to stack and setup 3 SG500X series switches Subscribe to Cisco's YouTube channel: http://cs.co/Subscribe.
Hello
sw1 -s2
conf t
no stack config
exit
wr mem
reload
sw1
config t
stack unit 1
end
wr me
reload
sw2
config t
stack unit 1
end
wr me
power off
power up sw2
show stack config
Kind Regards
Paul
