Cellular0 Interface keeps bouncing Up and Down
Patrick McHenry
Level 7
Level 7
got my 881 connected to Verizon via the PCEX-3G-CDMA-v card. I got a dhcp address from Verizon and am pinging Google from inside the router but, my Cellular interface keeps bouncing so, my pings are not too steady.
Console Messages|
May 29 15:08:12.143 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed sSecondary Home Agent Address = 0.0.0.0
May 29 15:08:37.295 EST-DST: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
May 29 15:08:42.367 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
May 29 15:08:57.512 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
May 29 15:08:57.536 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
May 29 15:09:43.841 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down
May 29 15:09:45.841 EST-DST: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
May 29 15:09:50.913 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Any ideas?
Thanks, Pat.
7 Replies 7
Tagir Temirgaliyev
put here
sh cell 0 all
what is a radio signal?
Not sure what you mean by radio signal but, here is the output.
Thanks, Pat.
sh cell 0 all
Hardware Information
Modem Firmware Version = p2102901
Modem Firmware built = 07-01-07
Hardware Version = AC597E Rev 1.0
Electronic Serial Number (ESN) = 0x60602D40 [09606303040]
Preferred Roaming List (PRL) Version = 52808
Current Modem Temperature = 0 degrees Celsius
Profile Information
Modem activated = YES
Account Information:
Activation Date: 20120529
Phone Number (MDN) : 6034408891
Mobile Station Identifier (MSID) : 6034408891
Data Profile Info:
Number of data profiles configurable : 5
Current active data profile : 0
Data Profile 0 Information (Active)
NAI (Network Access Identifier) = [email protected]
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Reverse Tunneling Preference = Set
Home Address = 0.0.0.0
Primary Home Agent Address = 255.255.255.255
Secondary Home Agent Address = 255.255.255.255
Data Profile 1 Information
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Primary Home Agent Address = 0.0.0.0
Data Profile 2 Information
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Data Profile 3 Information
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Data Profile 4 Information
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Data Profile 5 Information
MN-HA SS = Set
MN-HA SPI = 300
MN-AAA SS = Set
MN-AAA SPI = 2
Data Connection Information
Phone number of outgoing call = #777
HDR AT State = Connected, HDR Session State = Open
HDR Session Info:
    UATI (Hex) = 0080:0580:0000:0002:D50A:D06E:6C17:DB2F
    Color Code = 59, RATI = 0xD4162FD2
    Session duration = 672 msecs, Session start = 6422715 msecs
    Session end = 6423856 msecs, Authentication Status = Authenticated
HDR DRC Value = 14, DRC Cover = 1, RRI = 9.6 kbps
Current Transmitted = 1569 bytes, Received = 282 bytes
Total Transmitted = 1823 KB, Received = 247 KB
Current Call Status = CONNECTED Privacy Mode = OFF, Service Option = 33023
Current Call Duration = 20 secs
Total Call Duration = 47955 seconds
Current Call Type = AT Packet Call
Last Call Disconnect Reason = Base station release (No reason)
Last Connection Error = None
HDR DDTM (Data Dedicated Transmission Mode) Preference = Off
Mobile IP Error Code (RFC-2002) = 0 (Registration accepted)
Network Information
Current Service = 1xEV-DO (Rev A) and 1xRTT
Current Roaming Status(1xRTT) = HOME, (HDR) = HOME
Current Idle Digital Mode = HDR
Current System Identifier (SID) = 28
Current Network Identifier (NID) = 250
Current Call Setup Mode = Mobile IP Preferred with SIP fallback
SIP Username = [email protected], SIP Password = ^Rv^Zv)ck^X/[pO;Dq^X
Serving Base Station Longitude = -71 deg -33 min -2 sec
Serving Base Station Latitude = 42 deg 48 min 7 sec
Current System Time = Wed May 30 7:52:32 2012
Radio Information
1xRTT related info
Current RSSI = -63 dBm, ECIO = -3 dBm
Current Channel Number = 950
Current Channel State = Acquired
Current Band Class = Band Class 1
HDR (1xEVDO) related info
Current RSSI = -59 dBm, ECIO = -0 dBm
Current Channel Number = 1025
Sector ID (Hex) = 0080:0580:0000:0002:D50A:D06E:6C05:AA00
Subnet Mask = 104, Color Code = 59, PN Offset = 0
Rx gain control(Main) = -61 dBm, Diversity = Unavailable
Tx total power = -51 dBm, Tx gain adjust = 3200 dBm
Carrier to interference (C/I) ratio = 0
Modem Security Information
Modem PIN Security UNLOCKED
Power-up lock DISABLED
Radio Information
1xRTT related info
so radio signal is very good.
the problem may be when no traffic coming so dialer interface gos down, because no traffic.
I did
ip sla 10
icmp-echo 172.2.2.19 source-interface GigabitEthernet0/0
frequency 10
ip sla schedule 10 life forever start-time now
witch constantly sends icmp paket every 10 seconds so preventing dialer interface go down.
dont forget to rate post if it helps.
Thanks for the response.
I didn't configure a dialer interface.
This is my configuration for the Cell0
dialer-list 1 protocol ip list 1
script dialer cdma
interface Cellular0
description ***VerizonWireless***
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 2147483 either
dialer string cdma
dialer-group 1
async mode interactive
ppp chap password 7 00071A1507544B
and an acl:
script dialer cdma
And I also made cell0 the source for tunnel0 and tunnel1.
I was doing a constant ping to Google and I would still drop every 10th ping or so and then it would drop several pings in a row then connect again.
I haven't applied the NAT statements and an access-list that to the Cell0 interface and am thinking I probably should.
Access-list that is not applied yet:
Extended IP access list fw_acl
    10 permit icmp any any
    20 permit udp any any eq bootpc
    30 permit udp any any eq domain
    40 permit udp any any eq isakmp
    50 permit udp any any eq non500-isakmp
    60 permit esp any any
    70 permit udp host 192.43.244.18 any eq ntp
    80 permit tcp host 65.199.155.103 any
Here is some debug:
.May 31 10:08:33 EST-DST: Ce0 LCP: I TERMREQ [Open] id 103 len 4
.May 31 10:08:33 EST-DST: Ce0 IPCP: Event[DOWN] State[Open to Starting]
.May 31 10:08:33 EST-DST: Ce0 IPCP: Event[CLOSE] State[Starting to Initial]
.May 31 10:08:33 EST-DST: Ce0 LCP: O TERMACK [Open] id 103 len 4
.May 31 10:08:33 EST-DST: Ce0 LCP: Event[Receive TermReq] State[Open to Stopping]
.May 31 10:08:33 EST-DST: Ce0 PPP DISC: Received LCP TERMREQ from peer
.May 31 10:08:33 EST-DST: Ce0 PPP: Sending Acct Event[Down] id[4B6]
.May 31 10:08:33 EST-DST: Ce0 PPP: Phase is TERMINATING
.May 31 10:08:33 EST-DST: Ce0 IPCP: Remove route to 66.174.160.64
.May 31 10:08:33 EST-DST: Ce0 PPP: Outbound ip packet dropped, line protocol not up
.May 31 10:08:33.561 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.May 31 10:08:33.561 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
.May 31 10:08:33.565 EST-DST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
.May 31 10:08:33.569 EST-DST: %DUAL-5-NBRCHANGE: EIGRP-IPv4 99: Neighbor 10.3.68.1 (Tunnel1) is down: interface down
.May 31 10:08:33.569 EST-DST: %DUAL-5-NBRCHANGE: EIGRP-IPv4 99: Neighbor 172.20.68.1 (Tunnel0) is down: interface down
.May 31 10:08:35 EST-DST: Ce0 PPP: No remote authentication for call-out
.May 31 10:08:35 EST-DST: Ce0 LCP: Event[Timeout-] State[Stopping to Stopped]
.May 31 10:08:35 EST-DST: Ce0 LCP: Event[DOWN] State[Stopped to Starting]
.May 31 10:08:35 EST-DST: Ce0 PPP: Phase is DOWN
.May 31 10:08:37.553 EST-DST: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
.May 31 10:08:37 EST-DST: Ce0 PPP: Sending cstate DOWN notification
.May 31 10:08:37 EST-DST: Ce0 PPP: Processing CstateDown message
.May 31 10:08:42.625 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
.May 31 10:08:42 EST-DST: Ce0 PPP: Sending cstate DOWN notification
.May 31 10:08:42 EST-DST: Ce0 PPP: Processing CstateDown message
.May 31 10:08:52 EST-DST: Ce0 DDR: re-enable timeout
.May 31 10:08:52 EST-DST: Ce0 DDR: place call
.May 31 10:08:52 EST-DST: Ce0 DDR: Dialing cause ip (s=172.16.0.36, d=10.3.1.100)
.May 31 10:08:52 EST-DST: Ce0 DDR: Attempting to dial cdma
.May 31 10:08:52 EST-DST: CHAT3: Attempting async line dialer script
.May 31 10:08:52 EST-DST: CHAT3: Dialing using Modem script: cdma & System script: none
.May 31 10:08:52 EST-DST: CHAT3: process started
.May 31 10:08:52 EST-DST: CHAT3: Asserting DTR
.May 31 10:08:52 EST-DST: CHAT3: Chat script cdma started
.May 31 10:08:52 EST-DST: CHAT3: Sending string: ATDT#777
.May 31 10:08:52 EST-DST: CHAT3: Expecting string: CONNECT
.May 31 10:09:12 EST-DST: CHAT3: Chat script cdma finished, status = Success
.May 31 10:09:14.666 EST-DST: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
.May 31 10:09:14 EST-DST: Ce0 DDR: Dialer statechange to up
.May 31 10:09:14 EST-DST: Ce0 DDR: Dialer call has been placed
.May 31 10:09:14 EST-DST: Ce0 PPP: Sending cstate UP notification
.May 31 10:09:14 EST-DST: Ce0 PPP: Processing CstateUp message
.May 31 10:09:14 EST-DST: PPP: Alloc Context [84FACEC4]
.May 31 10:09:14 EST-DST: ppp185 PPP: Phase is ESTABLISHING
.May 31 10:09:14 EST-DST: Ce0 PPP: Using dialer call direction
.May 31 10:09:14 EST-DST: Ce0 PPP: Treating connection as a callout
.May 31 10:09:14 EST-DST: Ce0 PPP: Session handle[7F000022] Session id[185]
.May 31 10:09:14 EST-DST: Ce0 LCP: Event[OPEN] State[Initial to Starting]
.May 31 10:09:14 EST-DST: Ce0 PPP: No remote authentication for call-out
.May 31 10:09:14 EST-DST: Ce0 LCP: O CONFREQ [Starting] id 1 len 20
.May 31 10:09:14 EST-DST: Ce0 LCP:    ACCM 0x000A0000 (0x0206000A0000)
.May 31 10:09:14 EST-DST: Ce0 LCP:    MagicNumber 0x8A89F3A1 (0x05068A89F3A1)
.May 31 10:09:14 EST-DST: Ce0 LCP:    PFC (0x0702)
.May 31 10:09:14 EST-DST: Ce0 LCP:    ACFC (0x0802)
.May 31 10:09:14 EST-DST: Ce0 LCP: Event[UP] State[Starting to REQsent]
.May 31 10:09:14 EST-DST: Ce0 LCP: I CONFREQ [REQsent] id 104 len 24
.May 31 10:09:14 EST-DST: Ce0 LCP:    MRU 1500 (0x010405DC)
.May 31 10:09:14 EST-DST: Ce0 LCP:    ACCM 0x00000000 (0x020600000000)
.May 31 10:09:14 EST-DST: Ce0 LCP:    MagicNumber 0x12BB8B1A (0x050612BB8B1A)
.May 31 10:09:14 EST-DST: Ce0 LCP: O CONFACK [REQsent] id 104 len 24
.May 31 10:09:14 EST-DST: Ce0 LCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
.May 31 10:09:14 EST-DST: Ce0 LCP: I CONFACK [ACKsent] id 1 len 20
.May 31 10:09:14 EST-DST: Ce0 LCP: Event[Receive ConfAck] State[ACKsent to Open]
.May 31 10:09:14 EST-DST: Ce0 PPP: Queue IPCP code[1] id[151]
.May 31 10:09:14 EST-DST: Ce0 PPP: Phase is FORWARDING, Attempting Forward
.May 31 10:09:14 EST-DST: Ce0 LCP: State is Open
.May 31 10:09:14 EST-DST: Ce0 PPP: Phase is ESTABLISHING, Finish LCP
.May 31 10:09:14 EST-DST: Ce0 PPP: Phase is UP
.May 31 10:09:14 EST-DST: Ce0 IPCP: Protocol configured, start CP. state[Initial]
.May 31 10:09:14 EST-DST: Ce0 IPCP: Event[OPEN] State[Initial to Starting]
.May 31 10:09:14 EST-DST: Ce0 IPCP: O CONFREQ [Starting] id 1 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP:    Address 0.0.0.0 (0x030600000000)
.May 31 10:09:14 EST-DST: Ce0 IPCP: Event[UP] State[Starting to REQsent]
.May 31 10:09:14 EST-DST: Ce0 PPP: Process pending ncp packets
.May 31 10:09:14 EST-DST: Ce0 IPCP: Redirect packet to Ce0
.May 31 10:09:14 EST-DST: Ce0 IPCP: I CONFREQ [REQsent] id 151 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP:    Address 66.174.160.64 (0x030642AEA040)
.May 31 10:09:14 EST-DST: Ce0 IPCP: O CONFACK [REQsent] id 151 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
.May 31 10:09:14.690 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
.May 31 10:09:14 EST-DST: Ce0 IPCP: I CONFNAK [ACKsent] id 1 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP:    Address 75.219.97.123 (0x03064BDB617B)
.May 31 10:09:14 EST-DST: Ce0 IPCP: O CONFREQ [ACKsent] id 2 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP: Event[Receive ConfNak/Rej] State[ACKsent to ACKsent]
.May 31 10:09:14 EST-DST: Ce0 IPCP: I CONFNAK [ACKsent] id 2 len 4
.May 31 10:09:14 EST-DST: Ce0 IPCP: O CONFREQ [ACKsent] id 3 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP: I CONFNAK [ACKsent] id 3 len 4
.May 31 10:09:14 EST-DST: Ce0 IPCP: O CONFREQ [ACKsent] id 4 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP: I CONFACK [ACKsent] id 4 len 10
.May 31 10:09:14 EST-DST: Ce0 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
.May 31 10:09:14 EST-DST: Ce0 IPCP: State is Open
.May 31 10:09:14 EST-DST: Ce0 IPCP: Install negotiated IP interface address 75.219.97.123
.May 31 10:09:14 EST-DST: Ce0 IPCP: Install route to 66.174.160.64
.May 31 10:09:14 EST-DST: Ce0 DDR: dialer protocol up
.May 31 10:09:14.726 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.May 31 10:09:14.730 EST-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
.May 31 10:09:14.734 EST-DST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
.May 31 10:09:15.798 EST-DST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 172.20.68.7 on interface Tunnel0
.May 31 10:09:15.798 EST-DST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.3.68.7 on interface Tunnel1
Thanks, Pat.
Hello Patrick,
I have a similar issue (however having a different configuration and platform). DId you manage to solve it?
kyle
Kyle,
I found that you need a very stable 3G signal to make this option of any use. I had the router in my sun room for a while for testing and it kept dropping. The signal in the sun room is not very good. With my phone I would get 1 or 2 bars. In my Dining room I get a constant 3 or 4 bars and the 881 with the cell interface was pretty stable there. I could make calls and surf at the same time. When I was on the IP phone and had a Youtube video streaming there was a noticable delay with my voice. I think you need atleast a constant 3 bars to be worthwhile. Not very scientific, I know.
Good Luck, Pat.
JesseLunt2053
Visitor
I am experiencing the same issue on my 819-4G router. I am running 15.6. When pinging 8.8.8.8 I get around a 75% success rate. Here is my radio info:
Router#sh cell 0 radio
Current RSSI = -107 dBm
Current ECIO = -7 dBm
SINR = +6 dB
Radio power mode = online
LTE Technology Preference = AUTO
LTE Technology Selected = eHRPD(EVDO)
I understand this to be a very good signal. Am I correct?
