Every time i have to put write command then only switch works as per the configuration. how to solve this?
sundar ganesh
I have configured two separate switches (sg 300-24P) with trunk and vlan.
Switch 1:
Port 1: trunk, trunk allowed vlan 2
Port 2: Access, Access vlan2
Switch 2:
Whenever reboot the computer or simply unplug and re-plug the utp cable the switch is not working as per the configuration. If i put "write" or "copy run start" command then it works as per the configuration. Again if i unplug and re-plug to the port, the switch doesn't work as per the config. If  i put  again  "write" command then it works fine.
I have tried alot to solve, but no luck so far.
Pls help...
check if you might be hitting the bug below. There is no workaround other than do what you are already doing...
SG300-28PP: MAC addresses stop being populated until wr command is issued
CSCvi36745
Description
Symptom:
example of issue:
W130SSG300-28PP#show mac address-table
Flags: I - Internal usage VLAN
Aging time is 300 sec
Vlan Mac Address Port Type
1 00:00:00:00:00:09 gi28 dynamic
1 00:23:24:8f:2c:26 gi28 dynamic
1 00:23:24:e7:25:2a gi28 dynamic
1 00:23:24:e7:29:20 gi28 dynamic
1 00:db:70:3f:23:e1 gi28 dynamic
1 1c:1d:86:c4:e8:55 gi3 dynamic
1 2c:59:e5:d8:9b:9f gi28 dynamic
1 30:f7:0d:5c:9e:fe gi28 dynamic
1 30:f7:0d:7c:5f:6e gi28 dynamic
1 30:f7:0d:7c:5f:79 gi28 dynamic
1 30:f7:0d:92:33:b4 gi28 dynamic
1 34:64:a9:6b:b3:96 gi28 dynamic
1 38:63:bb:01:bc:c9 gi28 dynamic
1 6c:4b:90:27:4e:03 gi28 dynamic
1 7c:69:f6:39:20:23 gi28 dynamic
1 7c:69:f6:39:20:50 gi28 dynamic
1 c4:b9:cd:33:6b:aa 0 self
1 e0:4f:43:21:95:fb gi28 dynamic
1 e0:4f:43:21:a0:fd gi3 dynamic
1 f0:29:29:77:1c:96 gi28 dynamic
1 f0:29:29:77:1c:c0 gi28 dynamic
2 04:e5:36:43:68:ae gi28 dynamic
2 58:55:ca:bb:f9:ae gi28 dynamic
2 b0:72:bf:da:43:9d gi28 dynamic
2 f0:29:29:77:1c:96 gi28 dynamic
100 00:00:0c:6c:b2:2c gi28 dynamic
100 00:d0:5f:01:33:00 gi28 dynamic
100 0c:27:24:30:37:7e gi28 dynamic
100 1c:1d:86:c4:e8:55 gi3 dynamic
100 f0:29:29:77:1c:96 gi28 dynamic
W130SSG300-28PP#
W130SSG300-28PP#
W130SSG300-28PP#wr mem
Overwrite file [startup-config].... (Y/N)[N] ?Y
24-Mar-2016 01:06:45 %COPY-I-FILECPY: Files Copy - source URL
running-config destination URL flash://startup-config
24-Mar-2016 01:06:48 %COPY-N-TRAP: The copy operation was completed
successfully
Copy succeeded
W130SSG300-28PP#
1 60:c7:98:8f:03:83 gi5 dynamic********************
1 60:c7:98:8f:03:84 gi19 dynamic********************
W130SSG300-28PP#
W130SSG300-28PP#
W130SSG300-28PP#
successfully Copy succeeded W130SSG300-28PP# W130SSG300-28PP#show mac
address-table
W130SSG300-28PP#
Conditions:
MAC address for some network devices stop from being learned until wr is re-issued
Workaround:
execute wr command or running config startup config
CSCvi36745
Description
Symptom:
example of issue:
W130SSG300-28PP#
W130SSG300-28PP#
successfully
Copy succeeded
W130SSG300-28PP#
W130SSG300-28PP#
W130SSG300-28PP#
W130SSG300-28PP#
address-table
W130SSG300-28PP#
Conditions:
Workaround:
Am sorry, am not getting. Are suggesting me to put wr command for everytime?
