Change VLAN IDs problem
jeremy-rogers
Community Member
I have 4 vlans currently, 100,200,300,400. I have 2 offices and they both used the same numbers, but now I need to change on office because of a DR system that we are putting in. I need to change one office to VLANs 111-114. I understand that I can't just change the number. I have to create these new vlans and move the associated IP addresses. Here is what I did.
I created the new vlans
config t
int vlan 111
int vlan 112
int vlan 113
int vlan 114
remove the IP from the old vlans
int vlan 100
no ip address
int vlan 200
no ip address
int vlan 300
no ip address
int vlan 400
no ip address
add the ip to the new vlan
int vlan 111
ip helper-address 192.168.1.20
int vlan 112
ip address 192.168.2.1 255.255.255.0
int vlan 113
ip address 192.168.3.1 255.255.255.0
int vlan 114
ip address 192.168.4.1 255.255.255.0
Then I change the DHCP server (192.168.1.20) to use the new VLAN numbers. Then I change the Port channels to the access switches to the new vlan ids. Then the access ports on those switches. I then flushed the arp cache.
Here is the problem. All routing seems to be broken now. I can pull and IP from the DHCP server on the vlan 111 only. From the DHCP server I can ping 192.168.1.1, but not 192.168.2.1 or any of the other vlan ips.
What did I do wrong? Was I suppose to flush the MAC address table? Was I suppose to shutdown the old VLAN ids?
8 Replies 8
chrihussey
Sounds like it should have worked on the surface. Can you provide the config of the switch with the VLAN interfaces and possibly one of the access switches? It would make it a lot easier to help figure out what is going on.
Here the config for the core and one of the switches. For example, after making this change I could not ping from the DHCP server (192.168.1.90) to the default gateway on any of the other networks (not 192.168.2.254, 192.168.3.254, 192.168.3.254, 192.168.4.254), I could ping to 192.168.5.254, but this is VLAN 500 and I didn't change this vlan number. I am assuming that I didn't clear some cache somewhere.
OK, just trying to figure this out:
1- Was the DHCP server moved into the 111 VLAN when you made the change?
2- Were the VLAN 100-400 interfaces shut as part of the process? (It wouldn't hurt).
3- If you give a PC/laptop a static IP in the new VLAN will it work?
Yes
No, but I will do this this weekend and Clear the Mac address table
Even the DHCP server which has a static IP couldn't ping the default gateway on any other network, but it could ping the dg on its network. Weird because the reply is coming from the same physical router (we only have one router).
Yup I agree, shut the old interfaces (or remove them altogether) and clear everything (MAC, ARP, routes).
Just a thought, as a pre-check to taking your network down would it be possible to create a DHCP scope for another network (ie 192.168.10.x/24), temporarily assign it to one of the new interfaces, allow it on a trunk to an access switch and test just to make sure the VLAN is indeed operational?
Hello
From your config changes it looks like you just created the VLAN SVIs - did you create the VLANs themselves?
Does the output of "show vlan" on core/access switches show vlans 111-114. If not post the output of "show vtp status" from both switches.
Cheers
Andy
Hello
What port is your uplink to the next-hop for the default route?
Looks like youve haven't changed the vlan membership on a few ports , they still show the old vlans especially vlan 111 where your default route now resides, i am assuming this was vlan 100 prior to change?
interface Vlan111
 ip address 192.168.1.254 255.255.255.0
 ip helper-address 192.168.1.90
ip route 0.0.0.0 0.0.0.0 192.168.1.165
interface GigabitEthernet1/0/6
 switchport trunk allowed vlan 1,100
 switchport mode trunk
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
 switchport access vlan 300
 switchport mode access
interface GigabitEthernet1/0/9
 switchport access vlan 100
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/12
Did you create the L2 vlans for 111-114?
Can you ping the default next hop sourced from the L3 vlan interfaces?
res
Paul
Kind Regards
Paul
Reza Sharifi
So, you can ping the gateway for vlan 111 (192.168.1.1) and not any other vlan.
Can you ping the management IP address on the core (192.168.11.1) which is vlan1?
If not, I see "ip routing" is enabled on the core.  Can you turn it off and than turn it back on.
no ip routing
ip routing
and test again?
