Changing a Catalyst 2960 to Catalyst 9200 series
jmpandi2017
I'm new here.
I am trying to replace a catalyst 2960 switch with a catalyst 9200 series switch.
Is it possible for me to pull the configs on the catalyst 2960 switch and put it into the new catalyst 9200 switch?
Thank you in advance for the help.
2 Accepted Solutions
balaji.bandi
90% of the command should accept when I did 3750X  to Cat 9300, but what version of code running in cat 29XX matters here.
if this is old 12.X  then like example... QoS changed
I would advise Cat 9200, to upgrade to later IOS-XE code as suggested by Cisco.
Copy the Cat 29XX config to the note pad, start pasting on Cat 9200 (a few lines and Observ any errors) then start mitigating. the issue)
Once all is fixed, add the new Cat 9200 into the network and test a few devices working as expected, before you do cut over.
BB
ashishr
Hi @jmpandi2017
Most of the commands should be same, you may run into issues if you are running QoS policy-maps on 2960. You can refer to the examples in the following document to modify your qos configuration if required. if it is just auto-cos then you can simply enable it on Cat9K interface as well.
3750 MLS to 3850 MQC Conversion of QoS Configuration
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html
Ashish
balaji.bandi
BB
Hi Balaji.bandi
Thank you for the quick response.
I'll try and let you know of the outcome.
ashishr
Hi @jmpandi2017
Ashish
