Changing LACP Loadbalancing Option
datamodule
Guys,
I have following question we have 6500 series switches by default all port channel loadbalancing is src-dst-ip.Now we have a requirement to change LACP load balance method to src-dst-port.
1) If we change LACP loadbalance method whar are the effects we are going have on our core network and all the existing servers
Thanks for your help
acampbell
Basically yes it will affect all PORT CHANNELS
However you can change this on a per MODULE basis.
Would only help if all your port channel interfaces were on the same module.
Please see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/channel.html#wp1020804
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks for your reply and my main worry is going to be is there any issue will rise after the change or it will work as normal
This going to be Plus + for you older functions will remain same . But in case fixed source and destination IP where multiple app are running on multiple ports then its going to loadbalance based on flow.
Ajay
