Changing Policy Map on 4500 switch
mramj499
I'm trying to update the policy-map settings for our 4500 switch.  Below is the current config.
class-map match-any VSL-MGMT-PACKETS
match access-group name VSL-MGMT
class-map match-any VSL-DATA-PACKETS
match any
class-map match-any VSL-L2-CONTROL-PACKETS
match access-group name VSL-DOT1x
match access-group name VSL-BPDU
match access-group name VSL-CDP
match access-group name VSL-LLDP
match access-group name VSL-SSTP
match access-group name VSL-GARP
class-map match-any VSL-L3-CONTROL-PACKETS
match access-group name VSL-IPV4-ROUTING
match access-group name VSL-BFD
match access-group name VSL-DHCP-CLIENT-TO-SERVER
match access-group name VSL-DHCP-SERVER-TO-CLIENT
match access-group name VSL-DHCP-SERVER-TO-SERVER
match access-group name VSL-IPV6-ROUTING
class-map match-any VSL-MULTIMEDIA-TRAFFIC
match dscp af41
match dscp af42
match dscp af43
match dscp af31
match dscp af32
match dscp af33
match dscp af21
match dscp af22
match dscp af23
class-map match-any VSL-VOICE-VIDEO-TRAFFIC
match dscp ef
match dscp cs4
match dscp cs5
class-map match-any VSL-SIGNALING-NETWORK-MGMT
match dscp cs2
match dscp cs3
match dscp cs6
match dscp cs7
policy-map VSL-Queuing-Policy
class VSL-MGMT-PACKETS
bandwidth percent 5
class VSL-L2-CONTROL-PACKETS
bandwidth percent 5
class VSL-L3-CONTROL-PACKETS
bandwidth percent 5
class VSL-VOICE-VIDEO-TRAFFIC
bandwidth percent 30
class VSL-SIGNALING-NETWORK-MGMT
bandwidth percent 10
class VSL-MULTIMEDIA-TRAFFIC
bandwidth percent 20
class VSL-DATA-PACKETS
class class-default
bandwidth percent 5
And the interfaces they are applied to:
interface TenGigabitEthernet1/1/15
switchport mode trunk
switchport nonegotiate
no lldp transmit
no lldp receive
channel-group 16 mode on
service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet1/1/16
no lldp transmit
no lldp receive
interface TenGigabitEthernet2/1/15
no lldp transmit
no lldp receive
channel-group 15 mode on
interface TenGigabitEthernet2/1/16
no lldp transmit
no lldp receive
So this is what I was doing on the CLI:
4500INT-01#conf t
Enter configuration commands, one per line. End with CNTL/Z.
4500INT-01(config)#policy-map VSL-Queuing-Policy
4500INT-01(config-pmap)#class VSL-VOICE-VIDEO-TRAFFIC
4500INT-01(config-pmap-c)#no bandwidth percent 30
4500INT-01(config-pmap-c)#bandwidth percent 5
4500INT-01(config-pmap-c)#class VSL-DATA-PACKETS
4500INT-01(config-pmap-c)#no bandwidth percent 20
4500INT-01(config-pmap-c)#bandwidth percent 45
4500INT-01(config-pmap-c)#end
But then anytime I then run "show run", it doesn't reflect the changes I made.  How do I get these changes to actually apply?
9 Replies 9
Giuseppe Larosa
Hello @mramj499 ,
you should try in a maintenance window the following:
remove all the applications of the policy-map to physical interfaces
int type x/y
no service-policy ouput <policy-name>
make your changes
then re-apply it to all the member interfaces.
As an alternative create a new policy-map with a different name and then change the name of the policy-map in the physical interfaces
using
int type x/y
service-policy output <new-policy-name>
I use the second way most of the times for changes to  QoS policy maps
Hope to help
Giuseppe
Giuseppe, so I have the new service-policy ready.  If I make this change, will any traffic be lost between the two switches?  This is core switch for our network, so naturally concerned.  I will do this in a maintenance window, but want to warn other engineers of adverse side effects, if any.  Below is the new VSL-Queuing-Policy-1 with the new bandwidth percent allocations.
policy-map VSL-Queuing-Policy-1
bandwidth percent 5
bandwidth percent 5
bandwidth percent 5
bandwidth percent 5
bandwidth percent 5
bandwidth percent 60
class class-default
bandwidth percent 5
bandwidth percent 5
bandwidth percent 5
bandwidth percent 5
class class-default
bandwidth percent 5
And my command to run to apply the changes:
int te1/1/15
no service-policy output VSL-Queuing-Policy
service-policy output VSL-Queuing-Policy-1
int te2/1/15
int te1/1/16
int te2/1/16
mramj499
Found this is the logs:
Service-policy attached to VSL member ports cannot be modified or removed.
How can I make this highly necessary change?
You probably have to remove the port channel interface from the VSS first, e.g.:
interface port-channel 1
--> no switch virtual link 1
Hello @mramj499 ,
you really need a maintenance window.
If you need to remove the port-channel(s) from VSL as noted by Georg,  you need to have a way to detect Dual Active Detection.
have you deployed a DAD link using one of the possible methods fast hellos, BFD ?
Otherwise without a DAD link the two chassis will become both Active at the same time with very great impact on the network.
Side note:
removing a service policy does not cause traffic drops by itself but in this special case if you need to break the VSL link to be able to change the service policy you need a maintenance time window and you need also to be ready for console access in the worst case to reach the standby chassis.
Edit:
another possible option to be investigated is to check if it is possible to add a second VSL link to the existing one just to avoid to break the VSS pair. But I am afraid this may be not supported.
Hope to help
Giuseppe
We have multiple VSLs on this pair.
te1/1/15 <-> te2/1/15
te1/1/16 <-> te2/1/16
So I'm thinking try your method first of no service-policy and then service-policy with the new VSL-Queuing-Policy-1.  I would try this first on te1/1/15 and te2/1/15.  If that doesn't work, then I would take down the VSL on 15 <-> 15 and try no service-policy followed by service-policy again.
Since the 16 <-> 16 VSL would still be up, I should be able to take down 15 <-> 15 and still have the VSS working.
Thoughts?
Current configuration : 230 bytes
description Uplink to 4500INT-02
no lldp transmit
no lldp receive
end
4500INT-01#sh run int po16
Building configuration...
Current configuration : 152 bytes
interface Port-channel16
switchport
end
4500INT-01#sh run int te2/1/15
Current configuration : 192 bytes
no lldp transmit
no lldp receive
end
4500INT-01#sh run int po15
Current configuration : 153 bytes
interface Port-channel15
description Uplink to 4500-INT-02
switchport
switch virtual link 2
end
Hello @mramj499 ,
be careful you have the ports of port-channel 15 terminated on the ports of port-channel 16
This is the way that a VSS is configured a different channel-group is used on the two chassis.
in the moment that you remove the commmand switch virtual link2 under po15 you break the whole VSL
and you have dual Active
check if you have a DAD link between the two chassis.
Hope to help
Giuseppe
Right, the VSLs are actually:
15 Po15(SU) - Te2/1/15(P) Te2/1/16(P)
16 Po16(SU) - Te1/1/15(P) Te1/1/16(P)
ACR-4500INT-01#sh run int po15
description 4500-INT-02
switchport
end
description 4500INT-02
switchport
end
As far as DAD, I see it on te1/1/14 and te2/1/14:
interface TenGigabitEthernet1/1/14
description --VSL--Dual Active Detection link (Fast-Hello)
dual-active fast-hello
interface TenGigabitEthernet2/1/14
Hello @mramj499 ,
you have the DAD link between the two chassis so this should avoid to have the dual active in the network.
However, the standby chassis will isolate itself from the network using the DAD link to know the master is alive.
The real issue I see is that by breaking the VSL you break also the control plane communication between the two supervisors on the two chassis as far as I know.
So the real problem becomes how to make the changes on the standby chassis and how to reconfigure the VSL link on its side po15.
I'm not even sure that connecting to the console of the supervisor on the standby chassis will allow you to make configuration changes.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-9-0E/15-25E/configuration/guide/xe-390-configuration/vss.html#86656
>> "When a physical port is configured as a member of a VSL port-channel, a queuing policy is automatically attached to the VSL member ports. This queuing policy provides a dedicated queue for VSS Management, VSLP, BFD, Layer 2 and Layer 3 control protocols, and voice and video data traffic. Each queue is provided with a minimum bandwidth, ensuring that VSS management and control protocol packets are not dropped when congestion occurs on the VSL. The bandwidth assigned to a class of traffic is the minimum bandwidth that is guaranteed to the class during congestion. The VSL link uses Transmit Queue Sharing, where the output link bandwidth is shared among multiple queues of a given VSL port. Any modification or removal of VSL Queuing policy is restricted in a VSS system."
So I would suggest you to open a Cisco TAC ticket to ask if it is possibile to change the VSL QoS policy or you need to rebuild the VSS system (that is the worst possibile case).
Most of VSS systems I have seen on customer networks do not use an explicit QoS configuration on VSS member links and I have never tried to change it.
another option is to evaluate again if you really need this change or not.
Hope to help
Giuseppe
