check nexus 3k licensing
nflnetwork
hello i have the following switch
NAME: "Chassis", DESCR: "Nexus 3548 Chassis"
PID: N3K-C3548P-10GX , VID: V01 , SN: ######
How do i check if I have licensing for ALL ports on this unit?
Is it common for a switch to only have licensing only some of its ports and not all of them?
Thx.
6 Replies 6
zeuscyril
Level 4
Level 4
hi
here the brief 3548 24 port license also there but part number will be 3548 only
 Feature-Based Licenses for the Cisco Nexus 3500 Series
Feature License
Product ID
Features
24 Port License Package
24P_LIC_PKG
N3548-24P-LIC
24-port license for the Cisco Nexus 3548 Series switch.
24 Port Upgrade License Package
24P_UPG_PKG
N3548-24P-UPG
24-port upgrade license for the Cisco Nexus 3548 Series switch.
Layer 3 Base Services Package
LAN_BASE_SERVICES_PKG
N3548-BAS1K9
  • Static routing
  • RIPv2
  • EIGRP stub
  • OSPFv2 (limited routes)
  • PIMv2 (sparse mode)
Cisco Nexus 3500 Algo Boost License
ALGO_BOOST_SERVICES_PKG
N3548-ALGK9
  • Warp Mode
  • Warp SPAN
  • Static NAT
Layer 3 Enterprise Services Package
LAN1K9_ENT_SERVICES_PKG
N3548-LAN1K9
  • OSPF (unlimited routes)
  • BGP and VRF-Lite (IP-VPN)
Note
Requires Base Services Package.
LAN_ENTERPRISE_SERVICES_PKG
N3548-LAN1K9
Note
sorry i don't understand what you are telling me
even though you buy 3548 device there there is 2 different license one is 24 port enable license and 48 port enable licesne. so 3548 with 24 port license will allow only first 24 ports.
Reza Sharifi
If you try
show license usage
 You should be able to see the license installed.
No, that is not common. Usually, out of the box, all ports are enabled and the license is used mainly for feature sets.
This is what i see
N3K1# sh license usage
Feature Ins Lic Status Expiry Date Comments
Count
24P_LIC_PKG Yes - Unused Never -
24P_UPG_PKG No - Unused -
LAN_BASE_SERVICES_PKG Yes - Unused Never -
ALGO_BOOST_SERVICES_PKG No - Unused -
LAN1K9_ENT_SERVICES_PKG Yes - Unused Never -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
Does this mean only the ports 1-24 can be used. or is it ANY 24 ports out of the total.
1-24
