Bookmark
Subscribe
632
Netflow and PBR issue
CSCO11712155
Hi All,
I am using C2960XR as L3 switch - 15.0(2)EX1 . Some traffic is passing through the switch is processed by PBR. We are running Netflow on the egress ports but cannot see the traffic that processed by PBR on Netflow statistics.
Any ideas if both PBR and Netflow for the same egress ports are compatible?
I think ACL based NetFlow is not supported (PBR typically uses ACLs), that's probably why it doesn't work...
Check the restrictions for NetFlow Lite:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15-2_2_e/netflow/configuration_guide/b_fnf_1522e_2960xr_cg/b_fnf_32se_3850_cg_chapter_010.html#reference_18AACC69154F4B409E64FA400D488F3F
Hi Georg,
We are not using acl based Netflow. We are using PBR to redirect specific traffic to a separate link. When we are monitoring this egress port, we see all the traffic on Netflow except the one that was processed by PBR.
if possible try and configure NetFlow on the ingress port On ingress, policy routing comes last (NetFlow comes before)...
