Cisco 1811 Router keeps rebooting and Sys ok keeps flashing
jsandau
I am having a problem with a ciso 1811 router. The router keeps rebooting every 2 minutes or so. If I unplug everything form the router and power it on without any acat5 cable plugged into it it will stay on but the sys ok light will keep blinking, and if I plug a cat5 cable in then the router dosen't seem to recognize the cable. Any ideas what is happening? Thanks.
Nuts.  Contact Cisco TAC and get the router replaced.
16 Replies 16
Reza Sharifi
Is this happening with on board ports or a module you have installed?
If it is happing with a module, take it out and try a different port
All the stuff in the router is factory default.
jsandau
Here is more info. I tried to connect via consol cable and here is the output:
Error : compressed image checksum is incorrect 0x22D2C3E2
        Expected a checksum of 0x22D243E2
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80018000
PC = 0x0, Vector = 0x0, SP = 0x0
System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc
C1800 platform with 262144 Kbytes of main memory with parity disabled
The the router reboots itself.
The checksum is incorrect.  It is possible the download or transfer to the router was corrupted. So, try downloading the IOS again and load it into the router again.
maxim_ratinov
IOS is corrupted. You need to console to router and wait  about 3 minutes. After download new IOS from tftp using ROMMON commands. If new IOS will be ok, you have no issues.
Remember to find working IOS (you may download it from different router or cisco.com)
Do you have step by step instructions on how to do that? I don't know that much about the CLI or ROMMON. Also will I have to reconfigure the router once the new IOS is installed?
Something is not right.  IF the IOS is corrupted the router will go into ROMmon and STAY THERE.  If it constantly reboots then there's something else more sinister.
Can you post the entire bootup process please?
Here is the entire bnoot process:
%No specific protocol configured in class SDM_WEBVPN_TRAFFIC for inspection. All
protocols will be inspected
%No specific protocol configured in class sdm-cls-VPNOutsideToInside-4 for inspe
ction. All protocols will be inspected
%No specific protocol configured in class sdm-cls-VPNOutsideToInside-5 for inspe
This command has no effect on this line; use modem AT commands instead
% This command has no effect on this line; use modem AT commands instead
SSLVPN Package SSL-VPN-Client : installed successfully
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
Authorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
User Access Verification
Username: ******
Password:
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
*Cisco Name*>enable
Password:
*Cisco Name*#copy tftp: flash:
Address or name of remote host []? 10.11.100.100
Source filename []? c181x-adventerprisek9-mz.124-24.T4.bin
Destination filename [c181x-adventerprisek9-mz.124-24.T4.bin]? c181x-adventerpri
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]y
Accessing tftp://10.11.100.100/c181x-adventerprisek9-mz.124-24.T4.bin...
Loading c181x-adventerprisek9-mz.124-24.T4.bin from 10.11.100.100 (via Vlan1): !
[OK - 24564700 bytes]
24564700 bytes copied in 63.156 secs (388953 bytes/sec)
*Cisco Name*#verify flash: c181x-adventerprisek9-mz.124-24.T4.bin
% Invalid input detected at '^' marker.
*Cisco Name*#verify flash:c181x-adventerprisek9-mz.124-24.T4.bin
Verifying file integrity of flash:c181x-adventerprisek9-mz.124-24.T4.bin........
.....Done!
Embedded Hash   MD5 : AB4C3E742C47FB2B53E41C7DE04B0F57
Computed Hash   MD5 : AB4C3E742C47FB2B53E41C7DE04B0F57
CCO Hash       MD5 : A7C3ACEEC1F81C6ABFB24C247147E950
Embedded hash verification successful.
*Cisco Name*#config-register value
*Cisco Name*#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
*Cisco Name*(config)#show version
*Cisco Name*(config)#exit
*Cisco Name*#show version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15)T1
0, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 20:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
*Cisco Name* uptime is 6 minutes
System image file is "flash:c181x-advipservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1811 (MPC8500) processor (revision 0x400) with 236544K/25600K bytes of mem
ory.
Processor board ID FHK134975HW, with hardware revision 0000
10 FastEthernet interfaces
1 Serial interface
1 terminal line
62720K bytes of ATA CompactFlash (Read/Write)
*Cisco Name*#
*Cisco Name*(config)#config-register 0x2102
*Cisco Name*(config)#^Z
*Cisco Name*#show run | include boot
boot-start-marker
boot-end-marker
no ip bootp server
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class type inspect sdm-cls-bootps
permit udp any any eq bootpc
*Cisco Name*(config)#no boot system
*Cisco Name*(config)#$ flash:c181x-adventerprisek9-mz.124-24.T4.bin
*Cisco Name*#write memory
Building configuration...
[OK]
*Cisco Name*#reload
Proceed with reload? [confirm]y
Copyright (c) 2008 by cisco Systems, Inc.
Readonly ROMMON initialized
program load complete, entry point: 0x80012000, size: 0xc0c0
Initializing ATA monitor library.......
program load complete, entry point: 0x80012000, size: 0x176d214
Self decompressing the image : #################################################
#################################################################### [OK]
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 12.4(24)T4
, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 13:34 by prod_rel_team
export@cisco.com.
Installed image archive
ory.
1 Serial interface
1 terminal line
% IP: Bad domain name format - Configuring anyway%No specific protocol configure
d in class sdm-cls-VPNOutsideToInside-1 for inspection. All protocols will be in
spected
%No specific protocol configured in class sdm-cls-VPNOutsideToInside-2 for inspe
%No specific protocol configured in class sdm-cls-VPNOutsideToInside-3 for inspe
%No specific protocol configured in class sdm-cls-VPNOutsideToInside-7 for inspe
SSLVPN Package SSL-VPN-Client (seq:1): installed successfully
Username: ****
Password:
this session.
use.
*Cisco Name*>show version
*Cisco Name* uptime is 1 minute
System returned to ROM by reload at 14:00:09 PCTime Tue Sep 21 2010
System image file is "flash:c181x-adventerprisek9-mz.124-24.T4.bin"
--More--
ÿ
Error : compressed image checksum is incorrect 0x22DA0572
program load complete, entry point: 0x80012000, size: 0x1384424
Error : compressed image checksum is incorrect 0x0B8BBB46
       Expected a checksum of 0x0B8B7A66
ÿ
ÿ
loadprog: error - on file open
boot: cannot load "flash:c181x-adventerprisek9-mz.124-24.T4.bin"
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
rommon 1 >
I found this guide:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/prod_release_note09186a00800810f3.html
It seems pretty srtaight forward, but do I follow the instructiond for run from RAM installation or run for Flash installation?
Download the file again.  It's a software-caused crashed.
Otherwise, you can download the version previous and try that.
Same issue to an 1812 router, is stuck in Rommon, same software force crash message and variables.
This happened after an power outage.
Tried with another flash(4gb SanDisk - worked), downloaded the ISO several times through tftpdnld, same checksum error.
Any ideas on what could be the fault? the CF 64mb, the 128mb memory?
jsandau
Is this a problem that could have fixed itself? The router was off over the weekend and today I turned it on to try and upload the ios, and the router booted normally before I uploaded the ios.
No it wouldn't.  I'm suspecting the IOS is corrupted or something.
