06-27-2007 04:09 AM - edited 03-05-2019 04:59 PM
Hi Sir,
I'm considering to propose the CISCO1812/K9 to my customer. It has a built-in 8-port switch.
Can anyone tell me what are the features supported on the switch? It's good if you can provide me the list of features. I'm wondering if port security is supported.
Thank you.
B.Rgds,
Lim TS
06-27-2007 05:05 AM
Hi Lim,
It seems to be supported, check this link,
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd802a9470.shtml
~JG
Please rate if helps
06-27-2007 12:58 PM
Thanks for your response.
Unfortunately, it talks about Cisco 1841 (modular) not the 1812 (fixed config). I don't think the Cisco 1812 supports port security as I can't find the command on the router.
Thank you.
B.Rgds,
Lim TS
06-27-2007 01:20 PM
Kindly check these:
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8028a95f.html
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd8028a95b.shtml
HTH,
Mohammed Mahmoud.
06-27-2007 06:53 PM
I checked these links before I posted my question.
They don't mention in details the features supported on the built-in 8-port 10/100BASE-T switch.
Thank you.
B.Rgds,
Lim TS
