EtherChannels
cisco-pix
Community Member
Hi, I just want to confirm I have configured my network right:
I have 2 sites, A and B. Each has a 3560G and using 2 ports on each switch, I have trunked them and created an EtherChannel.
on A:
int range gi0/1 - 2
switchport trunk encap dot1q
switchport mode trunk
channel-group 1 mode auto
and the same on B:
int range gi0/1 - 2
What I really want to check, is it correct to set the channel-group number as the same value on both sets of ports on both sides?
bjw
Level 8
Level 8
channel-group numbers are only significant on the local switch. They do not need to match across switches. And can be set to the same value without affect.
Also note that in Pagp, if both sides of the etherchannel are in AUTO, it won't work. If one side is in Auto, the other needs to be in DESIRABLE. Or you could put both sides to mode ON.
bjw
Level 8
Level 8
Using auto PAgP on both switches prevents the PortChannel from forming dynamically. You should use desirable mode on one of them.
[edit] Sorry Bill didn't see your reply.
HTH,
Mohammed Mahmoud.
