Cisco 1921 LAN adapter unable to reach the outside
SMRHosting
The Cisco 1921 router has two routed adapters. One is GE0/0 which I am using for my WAN interface. It is working properly. The 2nd interface is GE0/1 which is being used as my internal adapter. It is running NAT. When I attempt to reach the internet it fails while checking the exit interface. Here is the report.
AttributeValue
Router ModelCISCO1921/K9
Image Namec1900-universalk9-mz.SPA.151-3.T.bin
IOS Version15.1(3)T
HostnameBulldog
Interface Details
AttributeValue
InterfaceGigabitEthernet0/1
IP address192.168.1.1
DescriptionNOC Link
Test Activity Summary
ActivityStatus
Checking interface status...Up
Checking for DNS settings...Successful
Checking interface IP address..Successful
Checking exit interface...Failed
Test Activity Details
ActivityStatus
    Interface physical status :Up
    Line protocol status :Up
    DNS lookup set :Yes
    Statically configured DNS servers : 8.8.8.8 8.8.4.4
    Dynamically imported DNS servers : 192.168.5.1
    Interface IP address :192.168.1.1
    Interface IP address Type :Static
    Exit interface found : GigabitEthernet0/0
    Exit interface found :GigabitEthernet0/0
Here is my running config
Building configuration...
Current configuration : 12963 bytes
! Last configuration change at 20:48:36 NewYork Mon Apr 2 2012 by dave
version 15.1
service password-encryption
hostname Bulldog
boot-start-marker
boot system usbflash0:c1900-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
no logging buffered
no aaa new-model
clock timezone NewYork -5 0
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool Noc
   network 192.168.1.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 192.168.1.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
crypto pki trustpoint TP-self-signed-4227729276
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4227729276
revocation-check none
crypto pki certificate chain TP-self-signed-4227729276
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34323237 37323932 3736301E 170D3132 30343032 31373432
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32323737
  32393237 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD97 9407A326 2B2C5E3E 1BEE848C 9DBA6E5E 359E481A 125294BA 19CCF853
  7CEE2B90 58275061 CAD3EEB6 F89CB220 15343AE9 B1BAF818 C94D3036 568EF9F8
  4280497F D1C3579F B8D2AB67 F523FE6A E651DC48 C60E85FC 5361997C 77ACF34A
  F344A000 5E8CDBC9 AB557E60 FC456A08 35B252AC C4CAD14C 181EB7AC AE75CA50
  7A9D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1483B6F0 CE5D321D CBA30EF9 A22617C3 04676E73 4C301D06
  03551D0E 04160414 83B6F0CE 5D321DCB A30EF9A2 2617C304 676E734C 300D0609
  2A864886 F70D0101 04050003 81810046 0F82C60C 30232665 46F56276 D6A23379
  E5341379 E62C72E7 93D99862 7536A8D2 4F6AB31F 0B11BC80 92AA1ED2 BC8647B1
  6251BB3E 2C84B1AF F4713786 4B13EB34 D6B21F15 17BE3A5D F919D499 844D16E5
  BC09185A 8CB1D9BA 10010A5F E82C06E8 6F278D51 EB5FC4D7 2DEBE794 1A25C41B
  CD114F2A C2CDF1F5 F8688F50 C2CAC3
            quit
license udi pid CISCO1921/K9 sn FTX1448Y05L
redundancy
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect gnutella match-any ccp-app-gnutella
match  file-transfer
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect kazaa2 match-any ccp-app-kazaa2
match  file-transfer
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
class-map type inspect match-any ccp-h323-inspect
match protocol h323
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect edonkey match-any ccp-app-edonkey
match  file-transfer
match  text-chat
match  search-file-name
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  req-resp protocol-violation
class-map type inspect edonkey match-any ccp-app-edonkeydownload
match  file-transfer
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect edonkey match-any ccp-app-edonkeychat
match  text-chat
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
class-map type inspect fasttrack match-any ccp-app-fasttrack
match  file-transfer
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect p2p ccp-action-app-p2p
class type inspect edonkey ccp-app-edonkeychat
  log
  allow
class type inspect edonkey ccp-app-edonkeydownload
  log
  allow
class type inspect fasttrack ccp-app-fasttrack
  log
  allow
class type inspect gnutella ccp-app-gnutella
  log
  allow
class type inspect kazaa2 ccp-app-kazaa2
  log
  allow
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  reset
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-http-allowparam
  log
  allow
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
  service-policy http ccp-action-app-http
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  service-policy p2p ccp-action-app-p2p
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface Loopback0
ip address 192.168.2.1 255.255.255.255
interface GigabitEthernet0/0
description $ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description NOC Link$ETH-LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
zone-member security in-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0/0
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
password 7 0816720B000A0C0346
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
rizwanr74
Level 7
Level 7
Please add this route on the router.
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
Let me know, if that helps.
thanks
