Cisco 2800 Pagent recovery
manojk6
Hi all,
i am getting bellow error after reloading the cisco2800 pagent router
rommon 1 > PC = 0xbfcd0908, Cause = 0x2000, Status Reg = 0x3040a803
PC = 0xbfcd0d54, Cause = 0x2000, Status Reg = 0x3040a803
5 Replies 5
Leo Laohoo
Connect the console cable and reboot.  Post the entire boot-up process.  I want to see where it fails.
Getting this error
WARNING: Break key entered while upgrade ROMMON  was initializing.
Do you want to fall back to readonly ROMMON? (y/n) [n] PC = 0xbfcd0d54, Cause = 0x2000, Status Reg = 0x3040a803
In ROMmon, enter the command "reset" and hit enter.  The router should reboot.
Tried but no luck
Are there any WIC/NM installed?  If yes, remove them all and reboot again.
