Cisco 2811 PoE Power Supply
glenmcredmond
Hi, What command is used to remotely discover if a 2811 has a PoE power supply installed. I have tried both the "show diag" and "show env" commands but cannot find a definitive answer.
Glen.
Calin C.
Level 5
Level 5
Hello!
Do you have an Layer 2 card in the c2811 (something like NM-16ESW in the NME port)?
Please paste here the output of "show version" to be able to help.
Cheers,
Calin
Hi Calin,
The c2811 has a HWIC-4ESW module installed.The sh ver is attached below.
Cheers.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID XXXXXXXX
6 FastEthernet interfaces
2 Serial interfaces
2 Serial(sync/async) interfaces
2 terminal lines
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Hi Glen,
Does "show power available" give you anything? I've not 28xx with a switch modulbe installed to check, but that command works on POE enabled switches.
Kevin
Hello!
You have PoE on HWIC-4ESW. You can read the specification of the card here: http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
Cheers,
Calin
