Cisco 2850 and Fios Router
smutnpj10
I'm trying to configure a Cisco 3850 with Fios.  I'm able ping across platforms and can ping all vlans.   I can't connect to the internet when I connects clients to any of the vlans.  Here's what I have on the switch: (192.168.1.1 is the Fios Router)
ip routing
ip dhcp excluded-address 192.168.20.1 192.168.20.9
ip dhcp excluded-address 192.168.30.1 192.168.30.9
ip dhcp excluded-address 192.168.99.1 192.168.99.10
interface GigabitEthernet1/1/1
description Connection to FIOS Router
no switchport
ip address 192.168.1.2 255.255.255.0
ip nat outside
router eigrp 10
default-metric 10000 1 255 1 1500
network 192.168.1.0
network 192.168.20.0 0.0.0.63
network 192.168.30.0 0.0.0.63
network 192.168.40.0 0.0.0.63
network 192.168.50.0 0.0.0.63
network 192.168.99.0 0.0.0.63
network 192.168.200.0 0.0.0.63
eigrp stub connected
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Reza Sharifi
Is that a 3850 switch? If yes, this switch does not support NAT. You need a router to do the NAT for you. Have a look at this post:
https://learningnetwork.cisco.com/thread/98132
Reza Sharifi
