Cisco 2901 Switch Module issue (Module Detected but interfaces not shown)
ssg14
I have a 2901 with all 4 modules populated:
- Module 0,1 ==> EHWIC-D-8ESG-P (8 port Gig switch PoE)
- Module 2 ==>  EHWIC-1GE-SFP-CU  (1Gbps WAN)
- Module 3 ==> HWIC-4ESW  (4 port FE switch)
2901 has normal non-PoE power , interestingly when running,  systems detects all modules:
However when checking interfaces , it doesn't detect the fast ethernet module interfaces:
4por FE module has no issue working , tested and not defected.
Any idea why i get such error? is there any chance PSU doesn't have enough power to turn all modules on? or module on the router motherboard may be dead?
Thanks for your help guys
Mark Elsen
 - Your command may only list ip-capable interfaces , also verify with show interface status , if duplicated attach a console and do a cold power-up , observe the self-tests and look for errors or anomalies
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
7 Replies 7
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for coming back , pls check below:
It doesn't show the FE interfaces , I checked the logs but no logs in respect to the FE module.
Will do a cold power and revert.
balaji.bandi
Looks for me for now PSU, show environment or show power give us more information.
also when you insert the module, can you captured all the Logs (if you can post that help to see what is wrong here ?)
BB
pls check below power status , i don't see any abnormalities
I'll do cold power and revert with logs
Appologies, i was expecting output of -  show inventory
BB
ssg14
Thanks to both of you , although super weird but in cold power up shows cards are not compatible which doesn't make sense!
Cold boot up mean, it power on any module you insert in to device, but rest will be checked later once the card in.
i am sure now you know the card is not compatable, so get right module to fit to needs.
BB
