Cisco 2940 Ping Timeouts, Packet Loss
packettracer86
recently a Win 7 user had several connection problems. The PC was connected to an 2940.
I checked the Switch and got Ping timeouts at different time intervals (from every 2nd packet untill every 20th packet).
The problem is recoverable and happens on different PC´s/Cabels with dif. OS (Win7, WinXP, Linux Mint).
I also used different ios versions:
c2940-i6k2l2q4-mz.121-22.EA12
c2940-i6k2l2q4-mz.121-22.EA13
c2940-i6k2l2q4-mz.121-22.EA14
and tried different settings like
duplex half/full
mdix
speed 10/100
and apparently speed 10 was the only thing that worked out.
CPU utilization looks also fine...
Any clue?
Greets,
---------    show ver.  attached ----------
IOS (tm) C2940 Software (C2940-I6K2L2Q4-M), Version 12.1(22)EA12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Tue 08-Jul-08 00:06 by amvarma
Image text-base: 0x80010000, data-base: 0x8068C000
ROM: Bootstrap program is C2950 boot loader
.... uptime is 22 minutes
System image file is "flash:c2940-i6k2l2q4-mz.121-22.EA12.bin"
cisco WS-C2940-8TT-S (RC32300) processor (revision J0) with 19868K bytes of memory.
Processor board ID FOC1343Z5MA
Last reset from system-reset
Running Standard Image
8 FastEthernet/IEEE 802.3 interface(s)
1 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:26:0A:AD:29:80
Motherboard assembly number: 73-8784-08
Power supply part number: 341-0085-01
Power supply serial number: HIC1302A1P4
Model revision number: J0
Motherboard revision number: B0
Model number: WS-C2940-8TT-S
Configuration register is 0xF
Have you tried with auto/auto ? Interface are free of errors?
i also tried duplex auto / speed auto.
Int shows no errors.
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0026.0aad.2981 (bia 0026.0aad.2981)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 100BaseTX
  input flow-control is unsupported output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1416 packets input, 119151 bytes, 0 no buffer
     Received 232 broadcasts (6 multicast)
     0 watchdog, 6 multicast, 0 pause input
     3748 packets output, 258638 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Could you please send us the port conf.?
Good Morning!
Here´s the port config.
interface FastEthernet0/1
switchport mode access
switchport access vlan 14
switchport nonegotiate
no cdp enable
spanning-tree portfast
interface FastEthernet0/2
no cdp enable
interface FastEthernet0/3
no cdp enable
interface FastEthernet0/4
shutdown
no cdp enable
interface FastEthernet0/5
switchport access vlan 499
shutdown
no cdp enable
interface FastEthernet0/6
shutdown
no cdp enable
interface FastEthernet0/7
shutdown
no cdp enable
interface FastEthernet0/8
no cdp enable
interface GigabitEthernet0/1
switchport access vlan 25
switchport trunk native vlan 25
switchport mode trunk
