Cisco 2960/4010 archive
Hi All,
I have configured archive feature on Cisco C2960X (Version 15.2(7)E1) and IE-4010 (Version 15.2(8)E1) switches:
archive
 path ftp://username:password@X.X.X.X/path/$h
 write-memory
 time-period 1440
However authentication fails, also fails for SCP: Login or password incorrect! log from FTP/SCP servers.
FTP only works, when FTP username/password are defined through ip ftp username and ip ftp password commands.
License for switches is lanbase.
For other switch models with Network Advantage license no problem with authentication for both FTP and SCP with the same username/passwords.
So why authentication do fail, is it related to license lanbase?
balaji.bandi
That is how we configure to archive the files to FTP.
I believe SCP or SFTP you need Secure config, I do not believe Lanbase can support this (honestly i have not tested - that is a limitation because of Lanbase image)
BB
